I am going friggin' crazy!
Old Aug 15, 2007 | 07:47 AM
  #26
Just swap radiators. I had a 280Z that would overheat only on the highway. Just didn't flow well enough. Swapped to a different radiator and that took care of things.
A stock Nissan radiator can keep a turbo engine cool in heavy traffic or on the highway in southern California heat with no fan shroud.
Old Aug 15, 2007 | 08:38 PM
  #27
im gonna try the na z31 setup once i get the stuff from a wrecker near bleach, apparently its cheap.
Old Aug 15, 2007 | 08:50 PM
  #28
DW280zx's Avatar
Originally Posted by WildmaN
As for the injector fan... It is no longer on the car anymore. I took that piece of crap off, early in the process. It is a obstacle, that gets in my way. And I know I don't need it. I have been running my other Z daily without it. And no problems whatsoever.
Is this what the thing that looks like a baby plastic turbo is? wow, i really feel like an idiot. i was staring at that thing for 10 minutes trying to figure out what it was...
Old Aug 15, 2007 | 08:54 PM
  #29
RodMoyes's Avatar
Doesn't post much...
Yup!
Or, as the Ricky Racer types reffer to it... The "Electric Turbo" !
Rod.
Old Aug 15, 2007 | 10:51 PM
  #30
thxone's Avatar
Hey WildMan...If the car is stock then you should only have stock type replacement parts, i.e. Thermostat, Radiator Cap, proper coolant mixture. If you don't know what is causing the "overheating" then you shouldn't use different parts other than suggested by the factory. You have replaced the waterpump so you should be good there. Get yourself a stock replacement thermostat and make sure you have the proper amount of coolant and the correct mix. You should have 11 1/8th quarts of coolant in the car including in the overflow tank. Remember, if you have an air pocket in the block it will also overheat so it is important to get the air out of the coolant system..or the block rather. Improper timing will cause overheating also. Running rich, not so much. Use a radiator cap with a 13psi relief pressure.
Carl's Z
Jun 20, 2007 10:36 AM
Oxide
Mar 8, 2006 06:13 PM
apollo
Oct 23, 2005 12:09 AM
NISMO LMR
Aug 27, 2004 06:33 AM
NISMO LMR
Jul 26, 2004 09:47 AM
