heating problem
Old Jan 28, 2004 | 09:14 PM
cm3's Avatar
cm3
heating problem
have an '82 n/a and had heater core replaced back in Nov. The guy did a poor job so the heat doesn't work properly. At first it wouldn't come on at all so took it to Pep Boys and had a vacuum test and they found nothing. So I kept trying it and still nothing. I messed around with it and found that if I let the cold air run for about a min. then turn to hot that the heat would run for about 3 minutes then it would cool off. so i would run the cold again for about a minute and then switch to heat and it would run for about the same time. does anyone know what this may be?
Old Jan 29, 2004 | 09:28 AM
Oh, you probably have the Auto Climate Control system on your Z. That whole heater/AC thing is just messed up on mine too.
Sounds like its as simple as your water valve closing after a while. I'm not sure on this, but that valve may not be manually controlled by the heat selection in the dash. It may also be dependant on a vaccume system and thermostat. Maybe try opening up the heater valve that you can see from the passenger side. jam the arm that opens it to keep it open. Then try running your heat. If that keeps the hot air flowing all the time then you've found your problem. To properly resolve the issue will take some planning on your part. You can swap the whole system to a manul heating control found in most 1979-81 280ZX's. I'd like to do that some day on mine.
Old Jan 29, 2004 | 12:27 PM
Jimmys83Z's Avatar
I did the swap on my 83 and it was easy. Everything plugged right back up and I like the manual so much more than that auto.....
Monkies
May 26, 2013 03:41 AM
venomgg
Dec 4, 2011 01:47 AM
Jahmon
Nov 14, 2007 06:30 PM
Loki_D_Wolf
12
Mar 26, 2006 09:45 AM
lostsol
Jan 13, 2004 07:33 AM
