group buy on tension rods
I talked to the guy that makes me my stuff, he says when he cam make 10 he will ... so who would be in on this ?
I'm down with it...
Rod. |
i will update on a prize when i get intrest to get this going
im done give me a RESONABLE price and you got it
I'm down with it, if it's a reasonable price. :023:
me too. ive seen the stock ones sheer after they replaced the stock bushings with the poly ones...
Question guys what are the tension rods might be a stupid question but i really dont know
littl bars that go from the botton rad. support to the front control arms. technotoy tuning sells a kit.
I'm interested
Ok ill get a prize estimate then sofar we have 4 people on the bandwagon
ok im in, gimme the price in canadian:unibrow: no just the us price, cause i know how it works with you guys, it ends up being 5 trillion dollars according to nismo's calculator.:048: are those the adjustible ones that were in that other thread??
Yes indeed the same as in my other thread
acutally, i might need 2 sets, one for the road car, one for the race car
if the price is right i will look into them.
Do you know what source he is using for the BMW ball joints?
Do you anticipate any problems getting these shipped to the US from the Netherlands once they're made? |
You get to adjust the caster.
And, with the ball joints, they won't sheer off from difficult geometry as a result of suspension compression and wheel turn in...
what happen to this?
im down.. if the price is rite...
Im pretty busy right nowgetting ready for a track day the 23rd and my flight to MSA the 25th when im back i will set it up, as i need donor rods ( that i can pic up in the US!):paranoid:
For what year car are these tention rods and are they the thing in the pic? If so let's here some prices and some benifits of these other rods please.
Attachment 4482 |
Yes, they are what you pointed out in the pic. With the adjusting nut, hey will allow you to adjust the caster on your front end without having to mess with shimming the stock mount point. With the ball joint, it will provide enough play to allow the rod to move freely and not bind when the suspension is compressed and you've got the steering wheel jacked in a weird way.
This is an uncommon occurance, but can happen. The biggest benefit is the on the car caster adjustment and it should give you considerably more adjustment than the factory rod would allow. Mine are adjustable, but don't yet have the ball joint. I was originally planning on a heim joint which would give nearly the same result, but if I can get Frank to tell me what BMW that ball joint came from, I'll go that way instead... |
they are of an e30 i will give you teh part number ..
so yeah you got me there ;) |
Hey count me in too!
