fuel psi gauge?
fuel psi gauge?
iam going to put a fuel gauge in right after the fuel filter and inbetween the fuel rail.... will this be the right spot i want to know what my feul psi is, so i can tell if my fuel pump is working right ......has anyone done this befor ...will leaveing the gauge in there mess any thing up. i want it inside the ride is that ok to do with a fuel gauge. or will i smell fuel ??
If it's an electronic gauge with a pressure sensor and a sending unit, then the only thing in the car is the wires. MUCH BETTER IDEA!
Of course, the electric gauge is going to be more expensive.
I would go with an electronic if you want it in the cabin.
Otherwise, just mount it in the engine compartment inline with the fuel line.
gauge installed
Ok got it all installed and put it to the test.... take alook
runs at 29psi at idle when rev up it hit the 35 psi maker hmmm should i get a new fuel pressure regulator ..or fuel pump it self....shouldnt hit the 37psi maker or above as its beening reved up and run right at 30psi ?
Originally Posted by Heat Rave R
I think that might be normal/desirable. Under greater load, you'd want higher pressure/more fuel going in. It's pretty much what those rising rate FPR's do.
so you think thats good ????? i missed your post yesterday sorry. so thats that it golden hmmmm i hope so.
ThatDude114
Jun 15, 2014 08:43 AM
i was thinking of changeing them to blue i dont know ...........
