fuel psi gauge?
Old May 3, 2005 | 02:19 PM
81 Black L28E's Avatar
fuel psi gauge?
iam going to put a fuel gauge in right after the fuel filter and inbetween the fuel rail.... will this be the right spot i want to know what my feul psi is, so i can tell if my fuel pump is working right ......has anyone done this befor ...will leaveing the gauge in there mess any thing up. i want it inside the ride is that ok to do with a fuel gauge. or will i smell fuel ??
Old May 3, 2005 | 03:19 PM
lww's Avatar
lww
Head Muckraker
Depends on what kind of pressure gauge you get. If it's a mechanical gauge then you'll have to run fuel line inside the car.... Yuk.
If it's an electronic gauge with a pressure sensor and a sending unit, then the only thing in the car is the wires. MUCH BETTER IDEA!
Of course, the electric gauge is going to be more expensive.
I would go with an electronic if you want it in the cabin.
Otherwise, just mount it in the engine compartment inline with the fuel line.
Old May 3, 2005 | 04:33 PM
dam well i order it already this moring its the inline stlye with out a BOX lame well i will hook it up in that spot got the fittings already to go ..
THANKS lww
Old May 3, 2005 | 07:03 PM
Heat Rave R's Avatar
Since the pressure should be constant, anywhere along the line would be fine. So the spot you picked is just perfect. If you get a mechanical fuel pressure gauge, you can get an isolator so that gas won't be plumbed into the car. Or, as was already mentioned, you can get an electric one (they're just expensive).
Old May 4, 2005 | 11:33 AM
isolator ?????????????????????? hmm
Old May 5, 2005 | 03:37 PM
gauge installed
Ok got it all installed and put it to the test.... take alook runs at 29psi at idle when rev up it hit the 35 psi maker hmmm should i get a new fuel pressure regulator ..or fuel pump it self....shouldnt hit the 37psi maker or above as its beening reved up and run right at 30psi ?
Old May 5, 2005 | 05:21 PM
I think that might be normal/desirable. Under greater load, you'd want higher pressure/more fuel going in. It's pretty much what those rising rate FPR's do.
Old May 5, 2005 | 06:01 PM
DynamicJ's Avatar
Z8 driver
Hey red, I like the hoses under your hood man, looks good!
Old May 5, 2005 | 06:50 PM
thank you go get some they have diff colors and there only $11.00 a bag at the parts store one bag was just eff i was thinking of changeing them to blue i dont know ...........
Old May 5, 2005 | 10:04 PM
I want to do my engine in white, but they dont' have white loom. Have you seen any out there in your big city?
Old May 6, 2005 | 03:38 AM
Hey red, verry nice man! It looks beautiful under the hood. I like how you painted the valve cover, and engine. Keep up the good work!
Old May 6, 2005 | 10:54 AM
so i think that it mite be running a little low from the it leaking a little around the gauge so i when a got some sealer my project for today
Old May 6, 2005 | 11:05 AM
so you think thats good ????? i missed your post yesterday sorry. so thats that it golden hmmmm i hope so.
ThatDude114
Jun 15, 2014 08:43 AM
pcaudell
Jul 6, 2009 03:44 PM
Ramen Sama
Apr 28, 2003 06:26 PM
Gimpey
Apr 29, 2002 04:42 PM
