Fuel gauge issues
Fuel gauge issues
I own an '81 280zx, and it seems the fuel gauge is stuck on empty. Upon doing lots of searching, it seems quite a few guys are having this issue, though I think mine might be slightly unique. I have done some testing, and have found the following:
1. When grounding the yellow wire that connects to the fuel level sender, the gauge only climbs up to between 1/2 and 3/4 full.
2. The voltage I'm reading from the yellow wire is only at 0.28V. This seems wrong, what is it supposed to be?
3. I removed the fuel level sender/float assembly and gave it a good clean. Resistance levels vary from around 20 to more than 100, which seems okay, but it is a little jumpy.
Any input would be greatly appreciated before I dive deeper into the wiring.
Thanks alot guys!
Thanks alot guys!
took a quick look at the fsm and couldn't find any help in the download version. I have a Haynes that has a complete circuit diagram but kinda small and I don't have the time trace out the circuit. four wires from the sender. white/blue, yellow, black, yellow blue. goes to a connector and then to the fuel gage but hard to pick out. I also dimly remember when I had the actual nissan manual that the electrical schematic was a pull out. Maybe look on line for either one of those as the download doesn't appear to have the electrical schematic unlike the z31 manual. About all I can help with on that. unless you have the complete diagram as you posted.
Fsm
The 81 FSM has a full color wiring diagram. At least mine does
And in the EL Electrical System section page 42 / 116 is the schematic for the combination gauges.. including the fuel gauge.
Thanks alot for the replies guys, much appreciated
That's a great wiring diagram! Cheers
ThatDude114
Jun 15, 2014 08:43 AM
