Front Sway Bar Size
Subscribe
May 8, 2008 | 12:30 PM
In the process of ordering a front end rebuild kit, but I don't know the size of the front sway bar. Can anyone help me out?
Reply
May 16, 2008 | 07:38 AM
You should be able to use the year, make, model & VIN number at a parts store or at least get the info from the Nisson dealership parts department for the info. Good luck
Reply
May 16, 2008 | 08:04 AM
Quote: Nisson dealership
Nisson or Nissan?
And you can measure the size with a caliper or simply use a measuring tape / a piece of wood on top (laying horizontally - the measuring tape vertical).
Reply
May 17, 2008 | 07:48 AM
the stock is around 7/8, or at least the metric equivilant. i upgraded from msa with the 1.125 front and 7/8 rear. what a difference in body roll and stability. just ask nismopick!! hahaha
Reply
May 17, 2008 | 12:42 PM
Indeed... Shady's suspension is NICE!!!
Reply
Sep 4, 2008 | 04:49 PM
I thinking of getting the MSA Performance sway bar kit. Is that the one you ordered Shady? I assume the performance is has the 1.25 front? So would just the sway bars make a big diff.?
Does anyone else have experiance with replacing sway bars? I want to reduce roll while cornering.
Reply
Sep 4, 2008 | 07:40 PM
yup thats the one i got, dont bother with it unless upgrading the whole shebang, its meant to be used as a system, not on its own. mine just ripped the frame mounts off in a really hard corner, so make bigger frame straps. might as well get shocks, springs, ureathane bushings and the ball joints for the tension/compression arms, or whatever ppl are calling them now.
Reply
Sep 4, 2008 | 09:32 PM
the kit comes with the end links right?
Reply
Sep 5, 2008 | 06:41 AM
Quote: the kit comes with the end links right?
If you buy the kit from MSA it does: http://www.thezstore.com/store/merch...ry_Code=PSDC05
Reply
Subscribe
