This Damn Rattle
Old Mar 26, 2007 | 01:19 PM
FubarI33t's Avatar
This Damn Rattle
I have been trying to track this damn lil rattle down for some time now. It have lifted the car up. and Banged on every lil everythign i could find (not the half shafts though) The rattle comes from the right rear of the car. and will only rattle once the car is moving. it's driving me crazy. and makes the Z look bad with it rattling while driving. and i get enough rattling from the right rear quarter window cause the bushing is bad in it.
Old Mar 26, 2007 | 05:26 PM
n00blar's Avatar
Just a thought, but I had the same rattling noise coming from the fuel pump. And like you said, it came from the rear right side of the car and only when it was moving.
Old Mar 26, 2007 | 05:43 PM
RodMoyes's Avatar
Doesn't post much...
It's the caliper hardware...
Rod.
Old Mar 26, 2007 | 07:41 PM
SpeciallySpiked's Avatar
I'm a Registered User!
if all else fails... check where the strut attaches inside, it might be loose
Old Mar 27, 2007 | 06:11 AM
FubarI33t's Avatar
Break assembly is on there like a rock. I went in that day i was bangin on stuff and checked all the bolts to the rear shocks. Found out two things though. Three lug nuts were not tight at all. i just bumped the 4 way. and they came loose. and here in a week or so. i got to put new breaks on the rear.
Old Mar 27, 2007 | 08:19 AM
RodMoyes's Avatar
Break assembly is on there like a rock...
That's great!
It's still the brake HARDWARE.
Rod.
Old Mar 27, 2007 | 08:23 AM
FubarI33t's Avatar
ok rod. Explain this.
Old Mar 27, 2007 | 08:28 AM
RodMoyes's Avatar
There are two sliders with springs across the top of the rear calipers that are there to dmapen pad movement... When the springs wear out, the pads rattle while you're rollong along because the rotor moving against them in an eccentric pattern makes them "Shake"
Been there, done that.
Rod.
Old Mar 27, 2007 | 09:25 AM
FubarI33t's Avatar
ok then. how expensive to fix this? all new calipers. or can i get just these "springs"
Old Mar 27, 2007 | 04:24 PM
captken's Avatar
"springs"
pad springs and pad shims...what I had you redo on the brake job you did on my car. You know, the factory parts you left out when you did it the first time, the ones you said I didn't need.
Old Mar 28, 2007 | 07:06 AM
FubarI33t's Avatar
First off. those were on the FRONT and you don't need them for anything. were talkin about the REAR and nothing had to be redone.
Old Mar 28, 2007 | 07:12 AM
they do rattle, i got the same problem, but finding a hardware kit has been difficult. i did zachrates rears on his 79, and it even had the stock little stainless anti squeel shims. it was nice to see those. someone has lost mine years ago. so i get rattle. and the top of the shock, if the shaft isnt tight, it will rattle, but you cant move it, only happens when hitting little bumps. try that, its simple too.
Old Mar 28, 2007 | 08:07 AM
ShadowWulf's Avatar
Ive had the same thing for awhile now, but it must be my brakes or something related to it. The rattle is loud as hell and embarasing, but as soon as i drag or engage the brakes at all it completly stops.
Old Mar 28, 2007 | 05:45 PM
captken's Avatar
You learn fast when you work on my car and leave parts off!
We did the fronts first, the rears last. Regardless, those parts are there for a reason.
zordietrying
Nov 17, 2010 01:39 PM
FubarI33t
Jan 26, 2009 05:48 PM
wgc_3
Dec 3, 2006 12:36 PM
Ian01
Sep 14, 2006 02:44 PM
THE_ONE
Dec 15, 2002 02:10 AM
