Clutch problems
Old Mar 3, 2011 | 06:49 PM
J-cubZ's Avatar
Angry Clutch problems
Ok ill try to make this as simple to explain as possibile. 1982zx turbo
New Clutch pressure plate & disc plus bearing installed by a shop about 1,500 miles ago.
New slave cylinder and SS hose by me
Used hard line from another Zx by me
New master cylinder
So my problem is the clutch doesn't seem to be disengage very well at all lately causing it to be very hard to shift at times, sometimes it shifts fine (at random but mostly when cold). The pedal doesn't travel very far to engage either. At one point the pedal went to the floor while at a light i was able to pull it up and drive it home. I put the new master cylinder in at that point. but the clutch feel and still isn't good at all. Would like to know what you guys think may be the problem. Thanks
Old Mar 3, 2011 | 07:04 PM
BlueKitsune's Avatar
Intrawebz Wizard
Have you looked up under the dash and made sure the push rod was adjusted properly? I think the freeplay of the pedal is around like 10mm. And have you made sure the hydraulics are properly bled?
Old Mar 3, 2011 | 09:52 PM
J-cubZ's Avatar
Ya Its proplerly bled. Is the 10mm how much of the end is through? The problem seems to be the pedal returning back up. Is there a spring somewhere that I need to check on? If so is it on the fork or the pedal?
Old Mar 4, 2011 | 12:05 AM
Maybe you have some air in the lines still. Bleed your slave cylinder first. Then if that doesn't help, bleed your clutch master.
Old Mar 4, 2011 | 09:40 AM
Intrawebz Wizard
The 10mm is how far you push the pedal down from the very top, to where you first start feeling resistance.
If its not pushing itself back up, only like 3 things that can be wrong. First it the adjustment of the pushrod, second, air in the lines still, and third would be a leaky or damaged slave cylinder.
87_silverz31
Apr 7, 2012 10:56 AM
cockerstar
Jun 6, 2008 09:37 PM
FairladyZ84
Feb 21, 2006 10:33 AM
Darius
Oct 14, 2005 09:04 PM
hndah8r
Aug 15, 2003 09:24 AM
