charcol canister
Old Feb 25, 2006 | 11:28 AM
DarrellBuddy321's Avatar
charcol canister
Where have you guys relocated your charcol canister to to clear the intercooler piping?
Old Feb 25, 2006 | 01:10 PM
jfairladyz's Avatar
You could try moving it to the lower fender well. Thats where I plan to stuff mine. Right in front of the wheel.
Old Feb 25, 2006 | 05:33 PM
s/cL3.0's Avatar
Bleach is my Hero
Get rid of it.. You do not need it .. I passed emissions without it..
Old Feb 25, 2006 | 05:44 PM
If I Get Rid Of It Can I Just Plug The Line Going To The Rear Or Just Leave It There. Ive Been Wondering About This Removal For Some Time.
Old Feb 25, 2006 | 06:41 PM
jfairladyz's Avatar
DONT plug the line going to the tank. Put a breather filter on it or something like that. Another consideration of not using the canister is that pressure tends to build up in the tank even when you leave the line open. The vacuum of the engine helps to depressurize the fuel tank. But all in all, NO, you dont need the canister. The only thing I'd be concerned about would be the fuel odor from the vapors venting.
I should also point out that you can find a canister off of some of the smaller import cars who's canister is only a fraction of the size of the Z's canister. I'm planning on keeping a canister, but going with a smaller one and tucking it down in the fender.
Old Feb 25, 2006 | 07:35 PM
So If One Was To Run A Vacuum Line From Intake To That Return Line It Would Be The Best Of Both Worlds?
Old Feb 25, 2006 | 09:04 PM
jfairladyz's Avatar
Not neccessarily. See then the vapor would have full time access to your intake manifold. Which may not be a good thing. That vapor could build up in the intake and lead to problems. I think the best option is to leave the canister and just relocate it somewhere. Like I said you can find smaller ones to cut down on weight and space a little bit. I've thought about removing mine altogether but if I stick in the fender well then it's really not in the way and it's benefits will out weigh it's cons. It's one of those better safe than sorry sort of things. Like the PCV valve. Do you need it? No. But it's still better to have it in there then to remove it and just run a breather filter.
Old Feb 25, 2006 | 09:16 PM
s/cL3.0's Avatar
Bleach is my Hero
I just capped everything and never really had problems
Old Feb 25, 2006 | 10:37 PM
jfairladyz's Avatar
Supposedly the pressure from the vapors will build in the tank if you do it that way. I guess how often you open your gas cap for fuel will dictate whether the pressure builds up high enough to get dangerous. Another thing is that you want some sort of vent to the gas tank so that the fuel being pumped out can be displaced with air from the vent. Our caps aren't designed to vent pressure. They're a solid type.
Old Feb 26, 2006 | 06:34 AM
s/cL3.0's Avatar
Bleach is my Hero
oh yeah.. hahah.. well I usually filled up once a week but I remember one time I was unscrewing and there was so much pressure it popped the cap off on the last thread and broke the LCD on the pump.. funniest **** that ever happened..
Old Feb 26, 2006 | 08:03 AM
Even With A Charcoal Canister, My Cap Has Gone Flying Off Too, Maybee Its Not Working!! Every Time I Take The Cap Off It Goes Hissssss, And Pushes Its Way Off On The Last Thread. Also that could be why i smell fuel occasioally.
Old Feb 26, 2006 | 08:40 AM
jfairladyz's Avatar
Yeah your vent line is probably plugged. Or you canister isnt working. It could need a new filter. Check the bottom of it. I think the filters are like $5-6 (US)through a Nissan Dealer.
Old Feb 26, 2006 | 09:57 AM
apollo's Avatar
Pro Pumpkin Carver
You know i was going to ask about that. Recently i noticed a stain right under the gas cap. I thought i might be from water deposits from when it rains or something. Could it be that pressure is building up and gas is leaking out due to a faulty cap and leaving the stain? It doesnt wanna come off. Granted its only primer still but its buggin me.
Old Feb 26, 2006 | 10:00 AM
I Know I Lost The O Ring That Goes Around The Cap, It Sticks To The Car Side Then Falls Off When Your Not Looking. It Would Also Leak Then.
Old Feb 26, 2006 | 01:59 PM
Or do what I did before with my '81. Take the filter out, and put cotton swabs back in. It worked pretty well, and I was just screwing around. And also the swabs are cheaper. Because I had no clue, on how or where to replace the filter.
Old Feb 26, 2006 | 02:29 PM
jfairladyz's Avatar
Thats actually not a bad idea
Old Mar 7, 2006 | 09:25 PM
so what about just putting a breather filter on the end of the vent line from the fuel tank, so the vapors just vent to the atmosphere?
Old Mar 7, 2006 | 09:30 PM
jfairladyz's Avatar
That works. Thats what I would recommend doing if you're going to remove the canister. That way atleast excess pressure can vent and no gunk gets into the line possibly blocking it up.
ZXT83
Sep 28, 2010 02:04 PM
280zx2by2
Nov 30, 2009 06:15 PM
BlueKitsune
May 31, 2009 09:46 PM
georgiaz
Oct 2, 2001 07:02 PM
