A/C and P/S Delete?
Old Jan 31, 2011 | 08:50 PM
BlueKitsune's Avatar
Intrawebz Wizard
A/C and P/S Delete?
My Z has been slightly overheating for awhile (3/4 gauge max) and as a last ditch effort I deleted the front half of the A/C system. This actually was my problem! Now my Z doesn't overheat anymore and it must have freed up some power as the engine is much more responsive (and quieter).
Now I'm wondering how hard it would be to delete the P/S. Right now it has the recirculating ball P/S system. Any ideas? I heard just capping the ports on the gearbox is all I need to do, while others say I have to change everything.
PS: Why is there no Aluminum radiators for the 280ZX? Didn't the 280Z use the same radiator?
Old Jan 31, 2011 | 10:12 PM
pete8717's Avatar
Sounds like your a/c clutch was starting to seize up man. Honestly I'd try swapping to a rack and pinion for a cleaner look but you could try that as well. Just make sure you flush some new fluid through there before you cap it all off. As for the radiator there is one through arizona z car by special request http://www.arizonazcar.com/radiator.html for $349. One out of Nopi for $204 http://nopi.com/dsp_parts.php?vsubpcdesc=Engine Compartment | Radiator. Try that search feature. lol
Old Feb 1, 2011 | 07:58 AM
Intrawebz Wizard
Hmm, I didnt think of that, I just knew that the condenser was somehow bent in far enough to nearly touch the radiator as well.
And while I was looking over the power steering system I noticed it had a few leaks, on the gearbox and the pump so I might just wait and go find a rack and pinion from a junkyard.
Thanks for the link on the radiator! I entirely forgot about Arizona Z Car!
Old Feb 1, 2011 | 05:02 PM
noboosts130's Avatar
Lurker
I deleted both on my car. I just pulled everything out and capped the lines. I don't think the lack of power steering is all that troublesome. If you switch to rack and pinion you may need to get the crossmember as well, but i'm not 100% sure.
Old Feb 1, 2011 | 06:02 PM
Intrawebz Wizard
I didn't have the power steering belt hooked for for awhile when I had an L24 in my Z. and I never really noticed a huge difference really. Glad to know you can cap it. that will save me like $500 for a new pump and not have power steering fluid all over the engine bay.
Old Feb 1, 2011 | 06:36 PM
Holy crap! $500 for a new pump? That's ludicrous! Where did you get that quote from? And there is a little difference without power steering. I drove without it in my T-top, and got used to it. But when I got my slicktop running, which has power steering. I noticed quite a bit of difference.
Old Feb 1, 2011 | 08:48 PM
Intrawebz Wizard
That was from when I last checked... I just checked now and found a reman one for $117... I'm starting to wonder if the part sites are trying to make me look like an idiot...
Edit: No wait, MSA has the pump for $540, So its more my fault for not looking around lol
Old Feb 2, 2011 | 10:43 AM
pete8717's Avatar
As far as I know you do need to change the crossmember because of the mount for the rack and pinion is a part of the crossmember if I remember correctly. I'll take a look at my fairlady Z next time i go home to find out.
Old Feb 2, 2011 | 04:38 PM
Intrawebz Wizard
Ok and thats fine with me, it gives me the excuse to install new control arm bushings lol
Old Feb 2, 2011 | 07:47 PM
Also, all you probably need to do is replace the seals and rotors in the pump, about $50 in parts and a couple hours.
Old Feb 2, 2011 | 08:11 PM
260zturbo's Avatar
Stupid Hurricanes...
http://www.z31performance.com/forum/...p?f=24&t=25258
For a z31 did it to a spare rack. But dont see why u wont help you
Old Feb 2, 2011 | 08:20 PM
Intrawebz Wizard
Where do you get the parts?
Not a member of that site so I can see it lol
Old Feb 3, 2011 | 05:48 AM
pete8717's Avatar
Power steering pump seals:
Bam
http://www.autozone.com/autozone/par...ier=21487_0_0_
Having trouble finding the other but if you call a parts store you can get them locally alot of the time. You'd be suprised what you can find the local parts stores. When i worked at AutoZone I sold many seals for steering gear boxes. They're out there.
Old Feb 3, 2011 | 04:29 PM
Intrawebz Wizard
Oh wow. I'll just do that then
Blazencannon
Dec 20, 2013 04:16 PM
Seannnn
Feb 19, 2013 05:16 PM
BrownBomberZ
May 6, 2012 03:50 PM
Rupe
Dec 19, 2011 02:50 PM
my78z
Mar 26, 2003 09:37 AM
