Body welding question
I'm starting the t-top again since its not deadly to be outside finnally. Now what put me out last fall was a seam let go between the floor pan and inner rocker. This is a perfect 1/16 gap from the trunk release to the ecu. Could I simply stitch weld the seam back in. Or should I metal brake a 90° peice of patch and grab the inner rocker and pan with some 1/8 plug welds?
I always overbuild... so I suggest using angle-iron.
http://www.masonrydepotny.com/wp-con...ANGLE-IRON.gif |
In our neck of the woods we call that hillbilly pinch welds.:023: Still up in the air trying to find a good brand of stripper. Like to get the under side stripped and patch up the lil spots. May need a new welder my flux-core makes such a dam mess. My buddy got that walnut blasting crap for a fiberglass car. Not sure if it got enough ass to cut thru "Rusty Jones" undercoating though. Plus what a mess!!
1 Attachment(s)
https://www.zdriver.com/forums/attac...1&d=1396848975
Oh and btw the Highlander quote is "I have something to say - It's better to burn OUT than to fade away"..... |
Originally Posted by FricFrac
(Post 333013)
Oh and btw the Highlander quote is "I have something to say - It's better to burn OUT than to fade away"..... Highlander Kurgan Church Scene - I Have Something To Say - YouTube Anyway I looked into "Klean strip" Aircraft paint stripper. Last time I did stripper I got the 5.00 napa crap and all it did was make a agitating slime that burnt like hell. Ol Rusty did a hell of a job I tried a sample with a puddy knife and that undercoat is thick. |
to get rid of the undercoat i find a propane torch and a wood chisel sharpened constantly to work very well. to rid myself of rust i use a twisted braided wire brush on a grinder and then just a cookie on a die grinder works well. to get in the corners and such i use a handheld spot blaster with silica as walnuts aren't as good for rust, more for gently removing paint.
Aircraft stripper
Originally Posted by Lesnocker
(Post 333088)
Kudos someone else remembers the 80s. Naw just a play on words during my head-gasket failure. Didnt think anyone would catch it so your the winner!!!
