Auxillary Injector Fan Needed?
Old Dec 31, 2005 | 02:32 PM
newb81280zx's Avatar
I am trying to get rid of unecessary components in my car that I never use or are not needed. I am wondering if the injector cooling fan is really necessary. So far I have removed A/C + CC, can anyone think of anything else?
Old Dec 31, 2005 | 02:33 PM
Skully's Avatar
no its not neccesary..im ditching mine...
Old Dec 31, 2005 | 03:16 PM
tickwon's Avatar
I don't have mine either...so far so good. It's been off for two years now.
Old Dec 31, 2005 | 03:59 PM
jfairladyz's Avatar
According to Nissan it's neccessary. The L's did suffer from vapor lock back in the day. But what with fuel injection and evolution of gasoline it's not really much of a problem anymore. Nissan only put it there cause the exhaust manifold is right under the intake/fuel rail so a lot of heat can build up there. Theres always the chance you could have a problem at some point but I've had mine off for two years and never had a problem. And prior to removing it the damn thing wasn't working anyways so you do the math. Just realize something could happen but it's not going to damage anything. The vapor will only form when the car is off so worst case scenario you have a tough time getting that sucker started if it ever does occur. Letting the pump run for a while will usually get rid of any vapor in the lines. You couldn't do this with old carbed vehicles cause the pumps were mechanical.
Old Dec 31, 2005 | 06:48 PM
FubarI33t's Avatar
speakin of how close the intake is to exhaust, I have takin every thing off the top of my intake(replaceing and cleanin while it's down anyway's, Mainly just an excuse to work on the car) I have noticed there some one has Deff been there before, and have takin off the intake before. The reasion, They were to damn lazy to put the heat shild back on. Will this hurt me? And since my blower work's, At least i found out that if you mess with the wrong wire on the water inlet, the blower turns on, I am gona leave it there till it stop's. Gives my motor more of a It Only came In This Car Thing, to all the V8 lovin red neck's around here.
Old Dec 31, 2005 | 08:14 PM
jfairladyz's Avatar
I forgot to put the heatshield between the exhaust and intake manifolds on before. By the time I realized it wasn't on the car I had already tightened up the intake and exhaust manifolds and didn't feel like pulling them back off to put that heatshield on (too lazy ) Drove it that way for a couple months with no problems til I had to the exhaust manifold off again to swap it out. Then I put the shield back in. In all honesty, it probably only helps block the heat for so long. After so much driving and it absorbs so much heat, it's not likely to make too much difference. To be on the 100% safe side, if you've got one laying around, I'd put it in there. But like I said, 2 months with no probs so...
Old Dec 31, 2005 | 10:26 PM
Lost Vegaz's Avatar
Is there a way to make that shield more effective J ?? Like higher heat composites, or polishing so it reflectes heat???
Old Dec 31, 2005 | 11:00 PM
im keeping my injector fan, it helps when you in the deserrt at 120*
Old Jan 1, 2006 | 01:31 AM
jfairladyz's Avatar
Wrap it in carbon Seriously, thats not a plug for myself. Carbon is even more resilient than metal at blocking heat. Eventually, it's going to heat up and give off similar heat to an all metal one, but it will take a lot longer and the carbon wont get nearly as hot as the metal. Right now I'm working on an all carbon heatshield for the exhaust manifold (the one thats shaped like a manifold). It's just a prototype that a customer is going to test on his car to see if it can take that much heat. Carbon can withstand extreme temperatures no problem. But we have to see if the resin can handle it. Thats why it's just a prototype for now. If it passes then I'll offer it up for sell to everybody else too. Carbon is a much better insulator than those metal shields. Right now I'm working on that one, and one for the brake master cylinder (almost finished) and the one that bolts under the intake manifold and blocks off the PCV hose (the shield that goes up and down). Only problem is that carbon costs a lot more than metal so it's a trade off. Oh it looks better too
Polishing wont really help. It's still going to heat up just the same. But it will look better polished
Old Jan 1, 2006 | 10:09 AM
nismo619's Avatar
i took off my fuel injector fan , but only after i decided to change to a lower thermostate to make sure my car ran cooler and didnt hurt my fuel injdtors in any way. personally i know that the fan comes on after u turn off the car and the heat builds up alot.. but if u run a cooler thermostate it doesnt come on , or at least it never came on for me..
Old Jan 1, 2006 | 10:43 AM
s/cL3.0's Avatar
Bleach is my Hero
dont need cruise control, the carbon canister, aux. cooling fan, A/C, heater, and all the relay boxes on the passenger side except for the headlight relay..
Old Jan 1, 2006 | 11:38 AM
Running A Cooler Thermostat Isnt The Way To Go, Coolong Systems Work In Reverse. To Much Flow And It Wont Cool. I Have A 195 In Mine Because My 3 Core High Density Rad Flows So Well It Doesnt Cool. And You Dont Need The Fan. Hey J Make Me Up A Carbon Heat Sheild, Would Ya
Old Jan 1, 2006 | 01:02 PM
jfairladyz's Avatar
which heat shield? And Shady is right, the lower thermostat isn't going to help. Alls that does is allow the coolant to start flowing sooner. The car is still going to hit it's normal operating temperature regardless of what thermostat you use. The L's have been shown to like that 195 degree spot. An all stock cooling system running whatever temp. thermostat is still going to hit same temperature. The only benefit of the lower temp thermostat is in hot weather, WHILE you're driving. And the injector fan only works while the car is shut off. Now an aluminum radiator would lower operating temps, neither one is much going to affect whether you need the injector fan though. It's more an issue of heat generated by the exhaust manifold that causes the vapor lock. Not the cooling system.
Old Jan 1, 2006 | 04:28 PM
Heat Sheild - All Of Them. Im Trying The Aluminum Route But Its Difficult To Form Without Having The English Wheel Anymore
Old Jan 1, 2006 | 06:56 PM
jfairladyz's Avatar
Yeah, once I get the molds done I'll let you know. Once the molds are done I can have the shields done in a day. I'll let you know, then you let me know
jeffers300
Mar 26, 2012 08:34 AM
FubarI33t
Aug 18, 2006 08:18 AM
81 Black L28E
Jul 8, 2005 04:54 PM
Mousier158
350Z Performance / Technical
Jul 18, 2004 11:42 AM
OutLAW Z
Apr 30, 2004 07:25 AM
