added some stuff to my ZX
Old Oct 18, 2011 | 02:08 PM
k1drift's Avatar
60mm throttle body, 2 inch spacer, 8mm street fire wires, ngk plugs, 2 inch rear wheel spacers, eneos oil change, yokohama advan tires, took power strearing belt off and shed some weight, last track time was 15.74. once i get a new fuel pump ill take it to the track again and see what my new time is. hoping to be in the 15.5 or less area
Old Oct 18, 2011 | 02:09 PM
k1drift's Avatar
pix soon once i get something to take pix with lol, looks alot cleaner under the hood now
Old Oct 19, 2011 | 10:18 AM
Originally Posted by k1drift
60mm throttle body
Did you see my post about this in the other thread?
Alone, a 60mm ("240sx") TB doesn't do anything but push the bottleneck back an inch. The intake neck must be bored to match, and convert to a gutted turbo AFM.
As for your other upgrades, they are good, but miniscule "power" upgrades... were you not using NGK plugs before? And tires aren't going to increase your track time unless you are having traction problems.
None the less, I look forward to hearing about the new time results. Every little bit helps when it comes to the track.
Old Oct 19, 2011 | 07:01 PM
OK what the heck is an eneos oil change. If it's some sort of hot oil enima I don't want to know....
Old Oct 19, 2011 | 07:12 PM
Do a coil upgrade and cold air filter then adjust the valves and get back to us
Old Oct 22, 2011 | 10:17 AM
k1drift's Avatar
did a msd coil, cold air intake, and did the valves awhile back lol
Old Oct 22, 2011 | 10:19 AM
k1drift's Avatar
i have not seen any post about the trottle body, and the plugs where all mixed up, ngk here autolight there... yeah. and i cant catch traction at the track to save my life so the tires will help
Old Oct 22, 2011 | 11:09 AM
mayhem052's Avatar
Do you go to UA? Sorry very off topic.
Old Oct 22, 2011 | 12:22 PM
Are you riding your clutch at launch? For a mostly stock (~130whp) 280zx, it shouldn't have any traction problems on even stock 14's.
Old Oct 22, 2011 | 05:03 PM
Well there are a couple of links....
Old Oct 22, 2011 | 09:00 PM
83turbo280zx's Avatar
you actually expect to gain .2 of a second by changing your fuel pump?
lww
Nov 15, 2011 11:41 AM
theramz
Sep 6, 2004 10:32 PM
AllmyZs
Nov 12, 2003 07:44 AM
REDPRL Z
Sep 9, 2003 03:03 PM
CrazyLotusTT
Jun 21, 2002 09:30 AM
