82 280zx Turbo info
Old Apr 26, 2005 | 09:50 PM
lifegrddude's Avatar
Externally Wastegated
Welcome to the boards, that's cool you all are going to do a resto on a turbo coupe. Well, you can take a look at my cardomain site, I'm pretty much in the same boat as you are: building on a tight budget. The best things for performance you can do would probably be an exhaust, intercooler, boost controller and mildly upgraded fuel system. I'm using an adjustable fuel pressure regulator with 370cc injectors (stock is ~260cc) and the boost is set to about 9 psi, with 10 used at the track. (I'll shoot higher when I get my headgasket changed to a metal one)
Some things to look out for while you're restoring the body, look under the battery tray, you might need a flashlight since it's riveted on there, but that place is notorious for rust. Check the frame rails in the engine compartment as well. When taking apart the engine, the studs on the engine for the exhaust/intake gasket like to break, so spray them down with a bunch of penetrating lube and let it soak for a day before you try to break the nut loose from it. Same deal goes with the factory downpipe since that cast iron will probably be rusted shut. I also had to take a pipe cleaner and clean the inside of the EGR tube out, 22 years of junk had settled inside it and was causing it malfunction. Just use some good carb/choke cleaner to break up the buildup.
Anyways, good luck on your project.
myxtaz
Oct 26, 2006 10:58 PM
knb13
Apr 19, 2004 01:29 PM
jkube
May 24, 2003 07:46 AM
jkube
May 23, 2003 07:36 AM
bonz
Sep 7, 2002 03:29 PM
