1983 280zx Na died at 70 mph Need help!
Old Mar 2, 2014 | 07:35 AM
83-280zxna's Avatar
Exclamation 1983 280zx Na died at 70 mph Need help!
Hey guys I am new to the z so go easy on me. I was driving down the highway when suddenly the car dies, all guages hit zero (except volt meter which is at 14v) and i am just coasting. All of the lights work in the car (door lights, head lights, over head and the ignition ding when key is in) but no accessory power to the radio. When I turn the key I hear no noise from fuel pump or any relays under my dash. Could this be the ignition switch itself? or the ignition control relay or IC module?
Old Mar 2, 2014 | 10:42 AM
zxguy1986's Avatar
Sounds like could be any of the above. Are they all original to the car? I would check ECU/harness connections first. Not sure if you mean this happened only once or if car is still dead. How about some info on the mileage, general condition, maintenance history, etc. Info can be useful here.
Old Mar 5, 2014 | 09:27 AM
Twiggs280zx's Avatar
Check your fusible links. When I blew the acc link the same happened.
Kevdogg
May 1, 2014 03:26 PM
zcargirl
Jan 10, 2013 11:52 AM
turboboost
Jun 23, 2007 10:24 AM
rgus30
Oct 13, 2006 07:31 PM
badz
Oct 8, 2003 03:48 PM
