Will not go above 1,000 RPM!
Old Jun 13, 2004 | 07:57 PM
lifegrddude's Avatar
Externally Wastegated
Could be due to vacuum leaks. Might be good to follow all the lines and replace any worn hoses. Check the rubber pipe that connects from the AFM to the throttle body, it could have cracks in it.
John 82ZXT
Old Jun 15, 2004 | 05:31 PM
duckyz's Avatar
Yep, sounds like vacuum hoses to me!
Old Jun 16, 2004 | 03:00 PM
Check to see that your head temp and block temp sensor are both still plugged in. Check the connection on the air flow meter. Make sure that is plugged in. It sounds like something that is compeltely unplugged.
Old Nov 6, 2004 | 12:00 AM
lww's Avatar
lww
Head Muckraker
Could definitely be a bad AFM. My '80 ZX had the same symptom when the AFM died.
Originally Posted by ratshavefeet
1980 280zx
car will start, but won't go above 1,000 rpm with pedal pushed to the floor and as soon as you let off the pedal it dies. So far I have tested the fuel pump(looks good).The car seems like its getting too much gas, I think it might be the pressure regulator. Any other ideas?
Old Nov 6, 2004 | 04:17 PM
Skully's Avatar
i got same damn problem lol..been trying to solve it for weeks now.!
