ZDriver.com
-   -   what could cause a bad missfire when cold? (https://www.zdriver.com/forums/280zx-performance-technical-79/what-could-cause-bad-missfire-when-cold-38221/)
aruiz714 Jul 30, 2013 05:31 AM
83 na 280zx. What could cause a bad missfire when cold? I accidently ripped the wire off the thermo switch could this cause it?
NismoPick Jul 30, 2013 07:21 AM
Yessir...
Originally Posted by NismoPick (Post 291798)
There are 3 sensors...
#1: Water temp sensor for dash gauge
#2: Water temp switch for the aux fan
#3: Thermotime switch for the cold start valve (n/a only).
From the FSM (you should download it here: XenonS130 - S130 Reference if you haven't done so yet). :D
http://i60.photobucket.com/albums/h8...M/TSensors.jpg
aruiz714 Jul 30, 2013 08:56 AM
Thank you mr. Pick. I was going nuts.
aruiz714 Aug 9, 2013 07:20 PM
Is the water temp sensing switch for the injector fan? It only missfires when cold once warm is drives amazing. Its so embarrasing leaving work with a bad missfire. Also the temp guage is at 3/4 at idle 1/2 on streets and 0 at freeway speeds what do those symptoms mean?
NismoPick Aug 9, 2013 08:03 PM
Yes, as stated above.
Check cold start valve, thermotime switch, and air regulator.
Check the connection (ohm test).
Check coolant level.
With an infrared thermometer, check temp at thermostat housing at operating temp, the check temp at lower intake hose. If cooling system is working properly, you should see a 20*F-30*F temp drop.
aruiz714 Aug 12, 2013 05:00 PM
How do I check the thermal time switch and cold start valve my computer is not working at the moment.
