trouble getting turbo swap running.
Old Jul 26, 2005 | 01:41 PM
MidnightToker's Avatar
Ok so i bought a 280zx with a turbo L28 swapped in and the engine runs so rich that i can't even get it started. Plugs are immediately SOAKED when the key is turned. spark and timing are good though. Now the guy i purchased the car from never completed the swap and the car still has the N/A ECU with the large single connector, N/A distributor, and the N/A wiring harness. I have since replaced the fuel pump with a new one made for the L28et and a turbo AFM i bought from ebay. My question is would the car in theory, run with the N/A ECU, distributor, and wiring harness or do i absolutely NEED to replace those parts with those for a turbo engine?
Old Jul 26, 2005 | 02:38 PM
What I have learned on here, from reading other posts. Is you have to replace those parts for the Turbo to work right. ECU, fuel injectors, AFM, distributor, etc... You can't run a Turbo on n/a components. Most of them anyway, I need some input from the pros here!
All aside, I want to eventually Turbo my '82 he is n/a right now. But later on I want to go all out, and replace everything, get a turbo motor, rebuild it if need be. And that way it will run right, because he will have the right components. Hope this helps you, hopefully other experts on here, will give you more info.
Old Jul 26, 2005 | 04:44 PM
assimilated420's Avatar
im not an expert but you need the turbo ECU, turbo AFM, turbo fuel pump & injectors, and i dont think you need the dizzy..
it may be dependant on year tho.. ask bleach on that one..
Old Jul 26, 2005 | 07:07 PM
s/cL3.0's Avatar
Bleach is my Hero
I think you can pull it off with a N/A ECU you will run more lean I would think. .. Was the motor timed #1 TDC when you put it in?? Also is it getting spark at al???
Old Jul 26, 2005 | 10:41 PM
you dont want to run lean with turbo though.. otherwise.. kaboom!
oh and if yu keep trying to start it over and over your engine is going to be overflooded.. take out the spark plugs and let it sit overnight.. when i was tryin to get my car started at first after rebuilding i flooded the engine and i couldnt get it started no matter what i did.. so i finall took the plugs out and just let it air out over night and came back in the early afternoon and replaced them and it started up within a few turns..
another option may be to just pull the plugs and dry them out and then spray some starter fluid in the intake and then try cranking it.. acetone and alcohol.. thatll get her goin in no time...
Old Jul 27, 2005 | 08:04 AM
Two options
Run all NA stuff. NA air flow meter, distributor, fuel injectors, ECU. Keep the turbo itself down to low boost. 5-6psi and no more. Premium fuel only.
Run all turbo stuff. (recommended) Turbo AFM, distributor, wiring harness to ECU, ECU, injectors. This way things will run proper for low and higher boost. Still do research on how to set up a higher boost turbo engine before you just start turning the boost up.
For now, take out that turbo AFM and stick the NA AFM in there and see what happens. Make sure the block and head temp sensors are plugged in. Both are on the passenger (right) side of the engine.
Old Jul 28, 2005 | 10:28 AM
alright ill try airing out the cylinders first to see if i can get this thing started. does it really take overnight to completely dry?
Old Jul 28, 2005 | 12:35 PM
well not necessarily.. depends on how flooded they are.. id clean off the plugs in the process..
Old Jul 28, 2005 | 01:05 PM
if you have acetone or some alcohol.. or starter fluid.. same stuff mixed.. spray that in the cylinders and replace the plugs and she'll be roaring in no time.. unless of course another problem is preventing you from starting.. 4 things you need to run.. air, fuel, spark, compression.. and it all has to be timed correctly.. youre getting spark and fuel you say.. and air usually is no problem so make sure your compression is good.. if all checks out then she should start.. acetone is HIGHLY volatile so just a smidgen will do ya.. that stuff is 10x more explosive than gasoline so BE CAREFUL! too much and you can easily blow out a cylinder if you use too much.. just a few drops in a cylinder.. otherwise just stick with starter fluid sprayed into the intake
Old Jul 27, 2008 | 03:32 AM
michanic220's Avatar
be carful with ether, it doesnt like pistons and can burn a hole through them if you use to much.
jaromgi
Jul 23, 2013 08:10 AM
Z-carforlife
Jun 25, 2013 10:01 PM
jrlogan280z
May 8, 2010 08:23 AM
Ratfink
Aug 11, 2008 12:37 AM
jvanen
Jul 5, 2003 11:48 PM
