Timing
Old Apr 8, 2005 | 06:39 AM
DoTheDrew888's Avatar
Timing
The timing can be changed by the position the cam gear is set at, right? This changes the position of the timing chain and the cam timing, correct? So my question is, How do I know where to set the cam gear? I have an aftermarket cam so this will effect the timing.
Old Apr 8, 2005 | 08:39 AM
EatmyDust's Avatar
The cam should be the same prety much. #1 cyl TDC #1 int. lobe TDC. I am close to posotiv on this. the key on the crank should line up with the notch on the cam.
Old Apr 8, 2005 | 04:33 PM
So what about my ignition timing? Will I have to play with that in order to make maximum power?
Old Apr 8, 2005 | 10:16 PM
duckyz's Avatar
Yes...abooultely. I don't know where you need to have it since I don't know what kind of cam you have.
Old Apr 9, 2005 | 09:08 PM
Here is my setup and cam specs:
-N47 Head *Port and polish / valve job*
-Schneider Race Cam (MSA Stage III)
-Flattop Pistons (9.8:1 Compression)
-Centerforce Dual Friction Clutch
-CAI
-3 into 2 Headers
-2.5" Pipes
-High Flow Cat
-Dynomax Ultra Flo Muffler
Cam: Lift(In/Ex): .460/.460. Duration(In/Ex): 270/280
Any suggestions? Is this the type of thing where I can just adjust it by ear or should I use my timing light?
Old Apr 9, 2005 | 10:30 PM
duckyz's Avatar
I'd start at -10* TDC (someone correct me if I'm wrong, please!!). See how it runs, take it for a good spin around the block. Make sure that your RPM's are staying around 900-ish at idle and that the idle is strong..not racing...a good strong idle.
That's what I'd do, but opinions differ.
Old Apr 10, 2005 | 01:12 AM
EatmyDust's Avatar
just pop your hood, and loosen the bolt on your distributor, and turn it slowly back and forth and hit the throtle linkage between each move, and leav it were it soots you. you might end up turning it and leaving it to your left if you like fast take off, but that is advanced I think.
sidneyam
Feb 21, 2011 05:51 PM
Datsun_Husky
Nov 17, 2010 05:48 AM
Fast240Z
May 25, 2005 11:13 PM
crazytvrguy280
Mar 27, 2005 08:39 PM
Zmedic
Jul 20, 2001 01:26 PM
