Strange Problem?
Old Jan 17, 2007 | 08:46 AM
RodMoyes's Avatar
Doesn't post much...
Strange Problem?
So, I have actually taken my Z out and driven it a few times in the last week. Last night, I pulled away from a stop light and was giving it some pretty hard acceleration, just as I was about to shift into second gear the car "Shut off" very abruptly and jerked... which basically re-started the car. It was not cool. Almost like maybe an electrical interuption.
I have been noticing other little electrical gremlins lately too and I wonder if they are related. For a while now, my stereo would cut off and back on much like the car did under hard acceleration changes. Maybe a bad battery cable? I know my combo switch needs help because every time I turn on the headlights, the high beams come on. I have to flick the switch a few times to make them stay off, but sometimes they will randomly come on again while driving.
Every now and then, the clock doesn't light up but it keeps perfect time.
My "Door" indicator stay's lit up, but I can't figure out why. both the door switches appear to be working.
My biggest issue right now though is the weird thing it did last night. Need to do some investigating.
Anyone else had this problem?
Rod.
Old Jan 17, 2007 | 09:04 AM
Sounds like some wiring probs... a hot wire (ignition / acc) might be grounding out.
So last night... all power went off at once? Did the lights go off when the car died?
Old Jan 17, 2007 | 09:15 AM
z-hag's Avatar
Queen of Yachts
you live in escondildo, so you dont live near the water now, but have you had the z near the ocean ?????????
corrosion=corruption of circuit-----
we have salty air, mon---good luck with yours-------i hope it is easy--if so many things are affected, would not the problem be something more toward the source????? do the things happen at the samer time or different times?????-------is your electrical snap sound sharp or is it not so sharp any more-------it is probably just the connections.?????????(praying)
Old Jan 17, 2007 | 10:15 AM
RodMoyes's Avatar
To answer both questions...
Yeah, everything went off at once. It was almost like the momentum of the car rolling forward in gear "bump started" it back to lfe. Like there was a brief electrical interuption. I don't think the combo switch problem and the sudden shut off are related, but you never know. I'm going to check out the battery and alternator/ground connections this weekend. The car runs like a raped ape though
My car never lived very close to the ocean either. It did spend a summer in Florida though where it rained every freaking day!
Rod.
Old Jan 17, 2007 | 12:56 PM
Carl's Z's Avatar
How about those wires coming from the ignition? Might check those as well...
Old Jan 17, 2007 | 06:36 PM
i would say your battery has a dead cell in it, and the plates touched together. if it does that too many times, it could lead to a fire or battery explosion. its either that or the cables are screwed. id say the battery. as for the rest, it could be the actual component problems.
Old Jan 18, 2007 | 10:22 AM
FubarI33t's Avatar
Head light thing is common. Mine did it as well. I replace the head lamp sensor in the engine bay. and it stopped. Door thing i have also. I just took the light bulb out for that one. And i don't Ever have to take my high beams off. Cause there not bright enough. No one notices. they think it's on low.
Old Jan 18, 2007 | 02:19 PM
Edz280zx's Avatar
I had a 79 awhile back that would just die all of a sudden. Turned out to be the alternator. I'd have to turn the key off and on and the car would run fine. May not be exactly what yours is doing but it might be worth getting the alternator checked out.
Old Jan 18, 2007 | 04:39 PM
RodMoyes's Avatar
^ Yeah, I'm thinking it's a bad connection at the alternator. I'll be out there looking at it this weekend.
Rod.
P.S.
Headlight sensor you say?
Donde esta es el "headlight sensor"?
Old Jan 19, 2007 | 04:22 AM
FubarI33t's Avatar
yup. I replaced it. and it all started workin fine. But that problem could be in your switch it's self
Old Jan 19, 2007 | 04:24 AM
FubarI33t's Avatar
Oh. and check the connection behind the igg. that blue connector is Not cliped in. if your feet catch a wire, it will loosin it up.
Old Jan 19, 2007 | 01:18 PM
RodMoyes's Avatar
I have a bad feeling about this one. Since I haven't been driving the Z very much (It sometimes sits for 2-3 weeks) every cat in the neighborhood has made it their place to hang out. I'm wondering what other creatures have decided to call it home. I'm scared to open the hood! Tomorrow will be interesting. I'll keep you all posted.
Rod.
Old Jan 19, 2007 | 01:25 PM
A fried pooddy cat!
Old Jan 22, 2007 | 01:39 PM
007max's Avatar
From NY to AZ
Might have a furball in your intake. Its pretty common on these cars.
On a more serious note, I had the same problem in my POS 88 Maxima due to a bad battery clamp. Every now and then the car would just shut off in traffic. I had to pull over, wiggle the cable, and the car would start right up again.
Old Jan 22, 2007 | 02:50 PM
RodMoyes's Avatar
Problem = Bad battery cable
Problem = Solved.
Rod.
Old Jan 22, 2007 | 02:54 PM
Woot! Woot!
Old Jan 24, 2007 | 09:08 PM
jmmorriso's Avatar
It's good that it's fixed, but take a look at the hot for the stereo anyway, cuz mine was fried and would intermittently shut off too. My batt used to hit the hood, that was fun at night!
Old Jan 25, 2007 | 05:06 AM
FubarI33t's Avatar
my battery is not even strapped in. But even with hard driving. I can not move it. it don't move at all. bigg *** heavy battery.
casperzxt
Mar 1, 2010 10:19 PM
Workman
Feb 21, 2010 11:55 AM
Grimmace
Nov 7, 2006 10:48 PM
DODthunder
Dec 26, 2005 08:08 PM
Phalkin
May 16, 2002 11:01 AM
