Starter problem PLEASE HELP!!!
Old Feb 21, 2011 | 12:10 PM
swapsun's Avatar
I recently swaped my 1980 280zx motor into my 1982 due to better body and the 1982 didnt run. everything is ready and hooked up and the starter doesn't work? wtf. battery is fully charged, fuel pump, gages, ect... all working. I went and had it tested, it works, and it worked when it came out with the 1980 motor. Any ideas
Old Feb 21, 2011 | 12:54 PM
Boostless's Avatar
check to see if your cables and connections are clean and tight. Is it not doing anything at all? no clicking or spinning noises?
Old Apr 7, 2011 | 06:52 PM
zstuff's Avatar
start?
hello so if you have aportable starter like mechanis push button the starter should work , did you plugin little wire to starter from ignition at back of starter?
Old Apr 7, 2011 | 10:12 PM
AKZX's Avatar
Have you gone out with a multimeter to see where there's power getting to the starter, if there is any? Just because the battery is good doesn't mean the power is going everywhere.
albertom8819
Apr 20, 2013 06:04 AM
Esc8p2NeverLand
Apr 11, 2010 10:11 PM
Switchtr3
Feb 20, 2010 09:38 AM
User395
Feb 3, 2009 03:15 PM
ZDriver85
May 14, 2005 12:21 AM
