sputters and backfires at 3000 rpm
Old Jun 3, 2008 | 07:11 PM
Ace Conductor's Avatar
Ok here's my problem:
I took the car down to home depot and noticed it was kinda surging and sputtering really bad intermittently. I paid it no mind and got back home and parked it. Today I got in the car for a quick drive, and noticed the problem was back. I checked the timing and it was 20 degrees. The fuel pressure was steady at 38 psi while at idle. I have no idea what is going on. It surges and back fires really bad from about 2500-3500 rpm. I can hear the turbo spooling really really loud but the car is not really moving anywhere. If i floor it, and get past that rpm point, it clears up sometimes.
I am so lost please help!
Old Jun 3, 2008 | 07:15 PM
couple things, one you could have a bad vacumme leak cause the turbo to spool more and have more sound, the other possibility is the AFM is bad or has a bad connection
Old Jun 3, 2008 | 07:43 PM
Ok i have to check the afm, but I really cant hear any vacuum leaks, you know, the sucking sounds bad lines usually make. I
Old Jun 3, 2008 | 07:47 PM
they dont always make that much noise... but yea the vac leak will cause a louder turbo spool but not the sputtering like that unless its massive
Old Jun 3, 2008 | 08:47 PM
This is the day of epic nissan fail
Well I know its getting late, but I think I made some progress. I see that there is a vacuum line broken off at the nipple on the evap canister on the passenger side by where the engine bay light is. After fooling with the car, I hop into my 200sx(s12) to go get some bbq ribs. It cranks and drives fine, and after leaving the restaurant, it wont crank. Just spins over. Oddly, a passerby stopped and said to push start it, and I say whatever since the starter is working, but get this, after a push start, it runs; only to about 3500 rpm. So after limping home, My wife tells me her grandad's pathfinder just crapped itself. On a side note, the pathy has 330,000 miles with only oil changes, a t-belt, and a starter ever done to it. Sorry for the long rant, but its just crazy that all these old lemons failed at the same time
Old Jun 3, 2008 | 09:08 PM
is the whole engine cranking or just the starter spinning? cause its possible the gear went out or the mechanism that kicks the starter gear out died. idk, sound lame. where are you from? out of curiosity?
Old Jun 3, 2008 | 09:12 PM
Niku-Sama's Avatar
eff good grammar
your S12, is it a 4 or a 6 cylinder?
Old Jun 4, 2008 | 05:07 PM
on the s12 the engine is cranking over Im getting fuel, it just wont crank on its own. Im from Mobile, Alabama. It has the ca18et engine in it.
The main thing is I got my Z running right again. I fixed that nipple on the evap canister, and looks like my no 6 injector plug worked itself loose, but after those fixes its running back to normal.
Old Jun 4, 2008 | 07:07 PM
thats good, glad i could point you in the right direction. and thats a cool car thats why when you said S12 200sx i was thinking maybe you were from another country
Old Jun 4, 2008 | 10:39 PM
Niku-Sama's Avatar
eff good grammar
did it origonaly have the turbo 1.8L in it or did some one else put it in there?
either way it kinda sounds like the MAF is ded on it.
Old Jun 5, 2008 | 03:58 PM
yeah thanks snwbrder for the help. I get so used to saying s12 b/c if I say just 200sx, everyone thinks the newer front wheel drive one (b14).
niku-sama, that is the original motor that came with the car, and I am also thinking it is the maf since it wont rev past 3500 rpm. I dont know, I have been really thinking about selling this junk and really focus on the 280 since it is my favorite car.
Old Jun 5, 2008 | 05:17 PM
200sx jdm yo! lol is it rhd? even though its the CA and not the SR it interests me
Old Jun 5, 2008 | 05:35 PM
no rhd man good ole usdm. honestly though, I think a ka24 in there would be the ticket.
Old Jun 5, 2008 | 05:45 PM
huh... didnt realizw they had USDM with the CA18ET in it. to bad it wasnt the DET. oh wells.
Old Jun 6, 2008 | 01:24 AM
Niku-Sama's Avatar
eff good grammar
frankly i would want the V6 200SX
but any s12's are hard to find unless they have been trashed. theres a nice one where i used to work but i dont think it fo sales
Old Jun 6, 2008 | 03:52 PM
Yeah those are nice. I like just about anything with a vg in though There is a white one around here with the v6 in it and it looks showroom. I was really hooked on the styling of the car especially up front. The squared off nose is so hot to me.
Old Jun 6, 2008 | 04:11 PM
heres some pics of the 2 lemons
This may be the wrong section, but since we was already posting in this one, I will go ahead and show of my junk.
Old Jun 6, 2008 | 10:32 PM
S130 looks to be a sexy setup just need to get the body work sorted out and paint
Old Jun 8, 2008 | 02:03 AM
Niku-Sama's Avatar
eff good grammar
what seat is that in the last pic?
(desperatly need seats!)
Old Jun 8, 2008 | 02:56 AM
the driver seat is a z31 seat. Those cars came with so many different seat setups, but this one is a manual type with the adjustable side bolsters.
Vedivan
Apr 25, 2014 08:52 AM
xBlastFemurx
Feb 12, 2013 11:39 PM
87zxt
Dec 16, 2012 12:05 PM
kennyscomp
Mar 27, 2010 07:25 PM
jjohart
Feb 10, 2005 10:23 AM
