Source For Aluminum Radiator
Old Sep 3, 2003 | 07:23 AM
zpeedracer25's Avatar
check out Speedway Motors
They carry all kinds of inexpensive racing type parts and have aluminum radiators that will work for $149. I believe the Chevy radiators will work, but you will need to fabricate mounts for it.
Old Sep 3, 2003 | 11:01 AM
I've got to do all that stuff myself on both my Zs but time and funds are short for a while. If you have a local pick and pull junkyard you may be able to come up with an even cheaper solution. I thought about installing an aluminum radiator out of a 1982 Volkswagen Rabbit that I found, but the plastic side tanks were cracked...doh!
Old Sep 3, 2003 | 11:02 AM
No problem John!
I need to do all that myself on both my Zs. You might find a cheaper solution at your local pick-and-pull junkyard. I found an aluminum radiator out of a 1982 Volkswagen Rabbit that would have worked nicely but the plastic side tanks were cracked...doh!
Good luck!
Old Sep 3, 2003 | 01:02 PM
I paid about $150 for an aftermarket replacement radiator from Napa! To get a better aluminum one for that much is great!
Mine cools fine though, and is only a couple years old now.
zomg
Apr 19, 2007 09:13 PM
81 Black L28E
Jun 27, 2005 12:09 PM
preith
May 4, 2004 06:02 AM
zryde
May 5, 2003 06:04 PM
jake
Aug 6, 2002 12:40 PM
