Smoke and water/coolent
Old Oct 4, 2003 | 06:56 PM
Jimmys83Z's Avatar
white smoke
Hey Bud, white smoke is usually fuel or water, if you are seeing the smoke when you start after its sat a good while then it sounds like could be an injecter dripping fuel after you shut down.Try before you start it (when you know its gonna smoke) take out plugs and look for a wet cylinder. May want to spin it over with plugs out (and coil wire off) just to see if any fuel or water come out. If its fuel, its an injecter, if its water then its gonna be a cracked head or head gasket. And you said it did not want to keep water in the engine so sounds like its gonna be in the head. If you have a plug thats discolored more than the rest check that cylinder closely........Also the lucas oil treatment is ok and want hurt anything......
Old Oct 7, 2003 | 06:13 PM
Jimmys83Z's Avatar
Dont know right off top of my head but if you disconnect everything on intake and exhaust you can lift off it all still attached to head. Will need help, sure all together its a little heavy.............
Old Oct 7, 2003 | 09:28 PM
icice9's Avatar
Super Siver & Black Stud
dude!!! you didnt even need to take off the intake or exhaust manifold to take the head off the block... all you needed to do was disconect the wire harness from the intake and all the hoses and fuel lines from it and disconect the exhaust from the exhaust manifold and take the head with the manifolds off the block as one unit!!!!! its a lot easier to take the intake and exhaust manifold off the head when the head is off the car... but when you put the head back on dont put it back on with the intake and exhause manifold on... thats just my tip!!! ive dont that job a few times already.. and not just on my Z..
Niku-Sama
Aug 29, 2008 08:23 PM
plainwhiteZ
Mar 7, 2008 12:37 PM
Dorifto
Nov 21, 2005 08:32 PM
RPS13_GZ32
Sep 15, 2005 05:26 AM
Customlock
Apr 15, 2003 06:42 PM
