Signal electrical Problem
Guest
Posts: n/a
Ok, When i turn my ignition on it instantly blow my flasher fuse in the fuse box (without even using my signals) , i've searched everywhere for a bad connection etc, but i can't find anything. I used my hazard lights to see if it was something to do with the actual lights or the wiring going to them but they all seem to work fine.Could it be that my flasher cube is dead or is it something else?
hmmm......if your hazzards work, it wouldn't be the lights themselvs.........shoot, try the flasher cube. Sounds like a good idea to me!!
I'd also get a Haynes manual and look at the wiring diagrams to make sure that you looked at everything.
brad101010
Mar 17, 2006 09:48 AM
JDsmash
Aug 12, 2005 11:30 AM
