Side seals
Old Jan 4, 2011 | 05:37 PM
gryt57's Avatar
Side seals
82 280zxt engine, I am in the process of rebuilding the engine. Putting the crank and main bearings in today, I was able to get the rear main cap after a mighty struggle with it. I hope the other caps are easier, anyway are the side seals suppose to be even with the block? The book I am going by says to trim them 1/16 of an inch below the bottom of the block.
The side seals, I have will not need any trimming if I push them in all the way. It seems if you let them project 1/16 of an inch below the block, they will get crushed by the oil pan. Or is that what you want?
Old Jan 4, 2011 | 09:09 PM
Which side seals are you asking about? I am a little confused. Are you talking about the front and rear main seals? Please clarify a little more. And maybe we can help you further.
Old Jan 5, 2011 | 04:14 AM
gryt57's Avatar
They are the seals, that go on the sides of the rear main cap. Between the block and rear main cap.
Old Jan 19, 2011 | 07:57 AM
ls1angela's Avatar
pictures , please . i dont see any side seals other than rear main seal , one-piece .
Old Jan 19, 2011 | 06:53 PM
gryt57's Avatar
http://www.partsgeek.com/catalog/197..._seal_kit.html
I ended buying the kit in the link above, the seals in the original rebuild kit I bought fit very loosely. The felpro kit had the expanders, and the seals fit much more snug. I trimmed the ends of the seals flush with the block, that is the best picture I can give you since the oil pan was installed yesterday.
pro1biz
Jun 17, 2011 04:42 PM
rb250zx
Jul 16, 2008 07:15 PM
melloyello
Nov 1, 2004 10:49 PM
thunderz
Feb 26, 2004 02:10 PM
quansta
Nov 28, 2002 03:28 PM
