Shifters
Shifters
I've noticed two diff shifters for the N/A. A round hole, with longer shaft below the piviot. and square hole. with shorter. From what i know the longer(higher) the shaft below the piviot point, the shorter the throw. so what year did these round hole shifters come on?
I'm not sure I've seen the difference. I did see that the later 280ZX had a plastic insert that slides a little where it pivots. My 1982 Z had it. I would make a guess here and say 1981-83 had the different shifter.
I know with my 82' I took the shifter out, heated it up in the vice and gave it a nice dog leg. Then I took that plastic piece you guys are talking about and flipped it upside down and it shortened the throw quite a bit, poor mans short throw shifter. I think its an even bigger difference with the S30's but if I rember the shifter is not interchangable between the early 80's and the late 70's. I bet the square hole is 79' or earlier, and the elongated one is the early 80's.
