SCORE LSD for my 280zxt
Old Oct 2, 2010 | 02:53 PM
zordietrying's Avatar
So I picked up a 88 300zxt for $500 today! It runs great and I drove it home! Finaly a CLSD!! Whats great too, is that a guy already offered me $1000 for it without the rear end. SWEET! Just got a few questions about the swap. Is it a straight swap for the rear ends? What rear end cover do I use the 280zx cover or the 300zx cover? And what rear end oil do you guys run in them and is there an additive I should put in for the LSD? Thanx
Old Oct 2, 2010 | 04:53 PM
pics hope it works
Old Oct 2, 2010 | 05:56 PM
BlueKitsune's Avatar
Intrawebz Wizard
Thats a really nice 300ZXT to tear up just for the diff...
Old Oct 2, 2010 | 06:35 PM
KHCreason's Avatar
really nice for 500 bucks! at least 3x as nice as mine was, for 1/2 as much cost. Therefore, it is really 3x 1/2 as good, which means is only 1.5 times better. so there. not much at all.
lol. tis nice indeed, and its cool that youll be able to double your investment quickly. Do you know his plans/
Old Oct 2, 2010 | 07:47 PM
Man, that Z is in nice shape. Seems to be a shame to strip the rear end out of it. You should sell it, and get the quaife pumpkin. NismoPick can explain it better for you. Good luck, with whatever you decide to do.
Old Oct 7, 2010 | 03:19 PM
I think he just wants a sports car and get decent gas mileage. But I dont plan on tearing the 300zxt up just swaping the diffs out, so the 280 will have an lsd and the 300 will have open. So can any one tell me what oil to use in the lsd ?
Old Oct 7, 2010 | 03:29 PM
http://www.az-zbum.com/information.basic.shtml
clutch diff: API GL-5 and SAE 80W-90 approved for Nissan LSD
Old Oct 7, 2010 | 03:58 PM
Do I need to get a different speedo gear so the speedometer will still read right with the 3.7 gears.
Old Oct 7, 2010 | 04:01 PM
J-cubZ's Avatar
Yup...
Old Oct 7, 2010 | 05:19 PM
260zturbo's Avatar
Stupid Hurricanes...
gear you want is in that tranny
Old Oct 8, 2010 | 12:25 AM
Which speedo gear do I use? And which diff cover do I use? I think I read some where that the finned one wont fit on a 280zx.
Old Oct 8, 2010 | 07:58 AM
You use the speedo gear for the diff you are using... thus the reason the speedo gear is "geared" to the differential gear.
The finned cover fits 280zx's, it does NOT fit S30's (240z-280z) due to the cross member support.
LSD installed in my 280zxt:
Old Oct 8, 2010 | 03:49 PM
I use the Redline 75W145. There are two versions - one has a friction modifier which I use in my 300ZX Vert (which is a LSD) and my 240Z and 280ZX get the Redline without the friction modifier (which are open diffs). (Oh and Redline 90MT for all my transmissions)
Old Oct 8, 2010 | 05:48 PM
Intrawebz Wizard
Thanks for saving that LSD for me Nismo! I'm still annoyed at you for that lol
Old Oct 8, 2010 | 09:27 PM
woops.
I still can't believe you missed it.
Old Oct 8, 2010 | 09:42 PM
I don't think I'm asking this quetion right, so I'll try again. My speedo will be telling me I'm going a different speed then what I'm really going.With the different gears in it(3.54 to 3.7). So to make the speedo tell me the right speed I'm going, what do I need to change? And Nismo I see in your pic you have the axles, will my cv axles fit in to that rear end? Thanx for all your help guys.
Old Oct 8, 2010 | 10:47 PM
Grab the speedo cog on the transmission (located on the transmission, where the speedo cable attaches).
Yes... the splines are the same for all long nose R200's, and the cv axles are the same length. It's LITERALLY plug & play.
In case you are wondering, no, you can't use the Z31 axles.
Old Oct 9, 2010 | 03:39 AM
Thanx again for the help. Anything else I need to know before I do the swap. I was thinking about taking it to an axle shop and having them check out it and have the seals replaced.
Old Oct 9, 2010 | 03:14 PM
As seen in the pic, you definitely need to change the cover gasket. Most parts stores don't stock it, so you'll either need to have it shipped in, or just buy a sheet of "do it yourself" gasket maker and cut one out (as I did for mine). I imagine you could buy the shaft seals from Nissan if they were torn, or just use the ones from your stock R200.
No need to waste money on a shop for something you can do yourself...
Old Oct 9, 2010 | 04:07 PM
Intrawebz Wizard
woops.
I know! I can't believe I did either!
Old Oct 9, 2010 | 07:43 PM
I was just thinking about bring it to a shop so they can check out the gears and make sure its all good to go.
Reptile00Seven
Dec 22, 2011 02:25 PM
CWHammer
Feb 22, 2008 11:22 AM
RodMoyes
Apr 29, 2005 09:08 PM
toomanytoyz
Aug 18, 2003 09:06 AM
280 drooler
Jul 16, 2003 11:48 AM
