ZDriver.com
-   -   poor take off (https://www.zdriver.com/forums/280zx-performance-technical-79/poor-take-off-34907/)
trent_mcgee6 Apr 14, 2012 07:40 AM
poor take off
i got an 82 280zx NA. this is my first z so i honestly know very little about them.
when i go into first, everything is fine until i let the clutch completly out then it just has no take off power. like it take alot longer to get to a point where i can shift. its slow on take off in 1st, 2nd, and 3rd. the only way i can get it to accelerate faster is by going to a high rpm before letting the clutch out.
things i have done to it:
NGK-R plugs
compression test
NGK plug wires
New dizzy
dizzy cap and button
valve cover gasket
cleaned throttle body with carb cleaner
seafoam vaccum lines
clean k&n air filter
clean AFM
still didnt help.
additional info
the dizzy i got had a different electric box on the side as my original. i swapped the out after i found that that box wouldnt let the car go past 3500rpm.
im not sure if my distributer is turned right where it needs to be.
i but a bottle of lucas upper cylinder lubricant plus injector cleaner and it seemed to help but i could've imagined it
any ideas?
ThaPimpShrimp Apr 14, 2012 08:53 AM
So.. you haven't set your timing?
trent_mcgee6 Apr 14, 2012 09:34 PM
no, i just set it in there and turned it till it sounded alright.
