P90 Pressure
Old Dec 4, 2009 | 05:04 PM
FubarI33t's Avatar
P90 Pressure
I need to know. Will a P90(not A due to hydro valves) withstand a comp ratio of 17:1(about 600PSI) unboosted. This is of course with larger ARP head studs and all metal head gasket.
Old Dec 4, 2009 | 05:47 PM
BlueKitsune's Avatar
Intrawebz Wizard
Holy **** O.o
Trying to build an LD28 or something? didn't they use iron heads?
As for your idea I think I would be more worried about the headgasket to be honest
Old Dec 4, 2009 | 06:23 PM
260zturbo's Avatar
Stupid Hurricanes...
jeez, how the hell you plan to get that? hope you plan to use some good race gas or hell jet fuel >_<
Old Dec 4, 2009 | 07:03 PM
PurePontiacKid's Avatar
i felld offa mai trike
It'll be fine, but with only 4 headbolts per cylinder, the likelyhood of the headgasket not failing is slim to none. 17:1 is unnecessary anyways. my dad's 9 second racecar doesn't even have that much (and it'll be in the 8's with not even that much compression)
Old Dec 4, 2009 | 07:46 PM
FubarI33t's Avatar
Jet fuel is diesel anyways, just a higher grade. yes it's for a LD28 project. Yes they have iron heads, i'm workin alot of the details useing CAD. Every diesel mech i've talked to and looked at a L-series head says it will hold just fine. but then again they have not used these heads. So i wanted ya'll opinion. I do plan on boosting it. but first i want it running N/A
Old Dec 5, 2009 | 12:41 PM
Jet A is actuall more of a kerosene. some has diesel and gasoline mixed in though. depends on which grade Jet fuel.
Old Dec 6, 2009 | 01:12 AM
skib's Avatar
This facepalm's for you!
BRAAP over on hybrid would prob be the best person to ask
Old Dec 11, 2009 | 11:03 PM
FubarI33t's Avatar
I have been talkin to Hybridz Z for a few days now. We have com to the conclusion that building this from a N42 instead of a LD block will be the best way to go. How say you?
So as far as Hybrid goes.
N42 block
P90 Head Modified as i spoke of before
Cummins 5.9L N/A Injection Pump.
Mild Turbo Cam, or Retarded Stock Cam
Stroker Crank-although i think i might be able to build a shorter stroke from a regular crank.
Old Dec 11, 2009 | 11:39 PM
i think its a waste of time. no offense, but wtf do you want with a diesel motor?
Old Dec 12, 2009 | 12:38 AM
FubarI33t's Avatar
it's for the 83. experiment.
Old Dec 12, 2009 | 09:54 AM
it's called imagination, some of us have it
Old Dec 12, 2009 | 10:03 AM
lol. oh yes, imagination.... i guess if you already got all the parts lying around it might be fun, but if there was supposed to be a functional purpose behind it or perform good idk, then its pointless haha.
greenemerald300
Aug 30, 2010 03:23 PM
FubarI33t
Apr 27, 2010 08:45 PM
tonsoffun300zx
Sep 21, 2009 10:51 AM
y2daniel1981
Oct 25, 2006 10:24 AM
91zxtt
Mar 5, 2004 11:00 AM
