overheating on the highway
Old May 22, 2003 | 09:07 AM
icice9's Avatar
Super Siver & Black Stud
you might need to change your thermostat... its not opening at the right temp and might cause it to overheat....
Old May 22, 2003 | 10:43 AM
lifegrddude's Avatar
Externally Wastegated
If the above doesn't work, check the pump and then the radiator. My Z had a bad radiator when I first got it. Took 5 hours to get home instead of 40 minutes! When I replaced it and took a look in the old one... Oh man, the amount of stuff on the inside was frightening.
John 82ZXT
Old May 28, 2003 | 09:58 PM
duckyz's Avatar
You might want to replace the upper and lower radiator hoses as well. Mine had the same problem. I found out that the upper hose, connecting to the thermostat, was weak and collapsed after a few minutes when the motor was up to temp.
Rickgosk8
Feb 8, 2015 06:08 PM
bataradena
May 2, 2013 06:23 AM
skygunner58203
15
Sep 15, 2012 10:04 PM
Shameless
May 18, 2004 06:44 PM
fantomZ
Nov 15, 2002 08:57 PM
