nixie tube sensor display pissing me off
so, ive searched the forums. read just about every page where someone has an issue with their "check" light. I've read how it's supposed to work, what to do when it doesn't do that...but mine is all f***y. here's the skinny:
since i purchased the car(81 280zxT) the display has never ran the check upon turning the key. it only runs the check when i depress the "check" button located to the right of the display. so, thats fine by me...for the most part. the problem is...the display used to go off after it ran thru telling me what was wrong; as of late...its stayed solid red.
here's the scenario:
turn key/start car
press check button
"washer" flashes(sensor is not working, its full of fluid)
then a solid wall of red dots...that doesn't go away.
even if i start the car and dont press the check, that damn red box is still there.
is there a way to re-set it?
turn key/start car
press check button
Lanoi
Apr 6, 2010 06:45 AM
