N42 Intake
Old Feb 20, 2008 | 10:21 AM
CWHammer's Avatar
Under My Car... brb
N42 Intake
Is there a valid reason to go to an N42 non-egr intake? Other than it looks really cool. If I did, what would it do to the emissions circuit of my '83 N/A?
Old Feb 20, 2008 | 10:28 AM
it would make emmissions harder to pass and no performance help at all.
Old Feb 20, 2008 | 02:16 PM
duowing's Avatar
NisTuner
It really wouldn't do anything as there really isn't an emissions circuit. You'd just be eliminating the EGR valve, which would require just plugging off a vacuum line and the EGR tube. Unless you have to go through an under hood inspection the EGR valve not being there won't cause you to fail emissions. I passed emissions with my Turbo ZX with a plugged off EGR, incorrectly hooked up AAC, etc and had no problems. The readings didn't differ much from my N/A 280ZX when it was emissions tested.
Old Feb 20, 2008 | 04:00 PM
CWHammer's Avatar
Under My Car... brb
Here in MI there is no emissions to pass. Would it help to dissipate the heat from the exhaust and keep the intake air cooler?
Old Feb 20, 2008 | 08:23 PM
no. like i said, its just MUCH cleaner. if you have a webbed (theres webbing between the intake runners) intake, the N42 isnt webbed so that MIGHT help dissipate heat. a lil
Old Feb 21, 2008 | 01:10 PM
duowing's Avatar
NisTuner
If there is a gain from removing the EGR, it's pretty much unnoticeable. If anything you're losing just a tiny bit of gas mileage as now you're missing out on that tiny extra bit of unburned fuel that gets recirculated. If anything I liked getting rid of the EGR simply because it was one less thing to get stuck open or go bad.
Old Feb 21, 2008 | 09:05 PM
CWHammer's Avatar
Under My Car... brb
I can dig that. I'll watch it and see where the price goes and decide from there.
Old Feb 21, 2008 | 09:43 PM
i recomend not paying anything over 100 dollars.
dhp123166
Jul 22, 2009 12:12 PM
dag88
Apr 14, 2009 07:27 PM
justinmy300z
54
Feb 12, 2006 11:01 PM
280ZX_AV8R
Jun 17, 2005 06:47 PM
thomas schuchat
Apr 17, 2003 11:26 AM
