The most boreing L28.
Old May 8, 2005 | 10:33 PM
juggalo280ZX's Avatar
Does anyone know what the maximum displacement is for the L28 block? If so, how much would the cylinders be bored over to achieve this?
Old May 9, 2005 | 05:30 AM
s/cL3.0's Avatar
Bleach is my Hero
I have seen 3.2L stroker motors I think the bore something like 1mm {not sure though} and they get a crank out os a maxima diesel engine.
Old May 9, 2005 | 07:38 AM
3mm overbore is said to be the largest safe bore on the L28 block. Add a stroked crank (with a lot of other machine work and mods to make it fit) and you're at about 3156cc or something. Barely able to round up and call it a 3.2L
More commonly called a 3.1L
Old May 9, 2005 | 08:02 AM
BigBirdsZ's Avatar
http://www.jimcookracing.com/catalog/page24.html
heres a 3.1 bore kit for the Z
Old May 9, 2005 | 08:06 AM
s/cL3.0's Avatar
Bleach is my Hero
Not worth the money at all.. MSA has one to.
Old May 9, 2005 | 08:41 AM
Fast240Z's Avatar
some guy on ebay is selling a stroker setup for 30 bucks.
Old May 9, 2005 | 10:55 AM
Dorifto's Avatar
Ask lww about this ... he's running a 3.1 in his ZXT, if I remember correctly. It's the one in the body shop right now.
Old May 9, 2005 | 11:32 AM
assimilated420's Avatar
3.2L is equal to 3156cc why are cc counts not quite that of the L? because even though they tell you 1 cc= 1 mL ...... it is actually .98625 cc = 1 mL... yes theyre both metric but they are very slightly off... i know the numbers seem frivolous but if you get into the whole spectrum of the physics realm of cars.. sometimes even the most minute amounts in certain equations can throw off a lot...
just thought i should clarify that
Old May 9, 2005 | 04:57 PM
jfairladyz's Avatar
Yeah but engine displacement isn't exactly an important detail. It's those fractions of inches and millimeters that need to be so specific. a thousandth of an inch can throw a main bore out of wack.
Old May 9, 2005 | 07:35 PM
well thats what i was referring to.. the physics aspects of the crank and bore and all those micro-measurements that keep the engine well balanced in its entirety
Old May 9, 2005 | 10:11 PM
Dorifto's Avatar
I say as long as mine is within spec ... I won't complain haha.
Still want that MSA 3.1 stroker kit ... or an RB25.
Old May 9, 2005 | 11:22 PM
lww's Avatar
lww
Head Muckraker
Rebello Racing will do a 3.2L motor, but you'll go through at least a half dozen blocks before you'll find one that will sonic test good enough to go to 3.2L.
Check out: http://www.rebelloracing.com/eng_info.htm
3.1L is much more practical and you won't loose much in performance with one tenth less of a liter except a lot more blocks that will be useable. And that can easily be fixed with boost...
You can get the same 3.1L kit from Courtesy Nissan for $1270:
http://tinyurl.com/8vyxx
Guess who MSA buys their 3.1L kits from? And they resell them for $1800!!
Old May 10, 2005 | 06:28 PM
Dorifto's Avatar
lww, you are a god. Now a stroker is definitely still in the long-term budget!
Old May 10, 2005 | 09:44 PM
duckyz's Avatar
I'm just looking for an N42 head to get started......
Old May 11, 2005 | 07:06 AM
excuse my ignorance, but what is a N42 head?
