Modifying the stock L28
Old Mar 30, 2004 | 03:19 PM
smartman3000's Avatar
Man, that stock motor doesn't really live up to it's power potential, so I decided to really give it some help. Here are some guidelines I thought up:
1. ABSOLUTELY needs to run on cat-**** octiane 87 gasoline. With 8.8:1 and aluminum heads, I don't think this is a problem.
2. No expensive machine work. No milling of the head or overbore or anything I can't do myself
3. Keep SOME low-end torque. I don't like full-blown motors that can't move around at low RPM.
I had the notion of a heavy port/polish on the intake, heads, and exhaust. This seems to be the cheapest way to do things. I was also contemplating possibly a cam with more duration to really get alot of fuel and air into the engine and really build up the pressure. I wouldn't think a header would be a major benefit on this motor due to its relatively small dispacement-- I might be able to get away with porting the stock exhaust manifold.
My question to you is, what is the obviouc restriction in this system? Is it just the ports are restrictive enough to not allow sufficient exhaust flow, or is there something else that keepd the poer numbers low?
I know plenty of engineers that say a well-massaged 6 cylinder can outperform an 8 cylinder simply because of its balance characteristics (crank doesn't absorb as much energy). Now I know there aren't any 2.8L V8s, but 200-220 HP in this engine shouldn't be too difficult, should it?
Thanks for any suggestions,
Brian
Old Mar 31, 2004 | 07:16 PM
duckyz's Avatar
Brian--- Funny you asked this question. I too am in the process of creating a 200hp n/a. If you do a search on this thread (200hp n/a??) you can see what it would take.
Old Mar 31, 2004 | 07:53 PM
Skully's Avatar
im pretty sure the larger TB and larger AFM would do you good (my 2 mods im working on with some help obviously) and a nice exhaust i have a 2.5" OD i think or something like that with no cat and its straight trough loud but hey...
not sure what else tho to put it up to 200....its not taht easy
Old Apr 2, 2004 | 01:29 PM
That's another good point. None of the 200hp L28s peak their hp at 5200 rpm like the stock motor does. They peak around 6500-7000rpm.
And, you'll never get to 200hp with the stock compression. No way, except with Nitrous.
But, you certainly can make it much more powerful than stock. Relatively speaking.
Mild cam. Dont' go overboard, especially on stock copression. 272 duration .450 lift. Call it good. That'll let your hp peak at about 5800-6000 rpm while maintaining all (or most) of your torque.
Port out the intake manifold (or make a manifold with larger runners) and port out the intake ports in the head. Leave the exhaust alone as well as the stock manifold. run 2.5" pipe off that manifold
Old Apr 23, 2004 | 08:42 PM
Spudz's Avatar
Are we talking at the wheels or crank HP ?? You can get 200 HP using oversized SU's. The head work is where all the power is hidden , also the low 8.3 - 8.8 to one compression isn't much help either. Most of the modern engines making over 200 HP are running more compression with a better electronics system.
An E Production 240 Z using a small cam and a limit of 12.5 to 1 compression
and SU's cam make around 240+ HP... And they are limited to .500 lift cam.
Mike
RPM
Mar 22, 2013 05:15 PM
TeamRonin
Dec 20, 2010 12:03 AM
casperzxt
Feb 15, 2010 11:05 PM
thetremendousti
Oct 12, 2009 06:27 PM
