Maxima head
Old Jun 3, 2004 | 03:05 PM
The Maxima head has higher compression. The Maxima uses the L24. The block has a short stroke and dished pistons so the head has very small chambers to keep compression up. When bolted onto an L28 it will make for a higher compression engine.
The Maxima head has smaller valves like a 240Z head so it is not good for high rpm performance right off the car. I suppose it is comparable to the E31 240Z head.
Old Jun 4, 2004 | 05:28 PM
FastZ's Avatar
Do you know the casting number off the maxima head? Is it the n47?
Old Jun 5, 2004 | 09:41 AM
FastZ's Avatar
I believe when put on with flat top pistons it will raise the compression to 10.1. We just did it on my friends 240 with a 83 lower block with stock internals. Made it a little bit faster.
Old Jun 7, 2004 | 08:42 AM
The earlier 280Z heads will give you higher compression but with an open chamber design. Its a toss-up as to weather they are better overall for performance. If you're against head shaving then its one of only a couple ways to get higher compression.
zero
Feb 19, 2011 07:40 AM
Sevan
May 13, 2009 10:41 AM
zend
Other Cars
Jul 22, 2005 11:34 PM
bagpipeswest
Dec 13, 2004 09:37 AM
Quickshift
Sep 23, 2004 01:18 PM
