lsd
Old Aug 2, 2010 | 06:07 PM
zordietrying's Avatar
lsd
I heard that you can use a r200 lsd out of a NA z32 for a s130. Has any one done that swap and if so what is needed to do that swap?
Old Aug 4, 2010 | 02:53 PM
its a z31 that swaps over. search that one, los of info
Old Aug 4, 2010 | 11:17 PM
Yes I know you can use the z31 rear end but they are hard to find, and the z32 are very easy to find. So....any one got some info?
Old Aug 4, 2010 | 11:31 PM
BlueKitsune's Avatar
Intrawebz Wizard
You can swap one but its a ton of work. its not a bolt in at all. you need to fab up a new front mount I think it is. then get a longer driveshaft
Intrawebz Wizard
You heard wrong.
And you need to shut up and read more.
Old Aug 5, 2010 | 06:18 AM
MurphyEF's Avatar
Anything is possible with the right amount of money and/or experience.
Old Aug 5, 2010 | 10:09 PM
skib's Avatar
This facepalm's for you!
possible? yes, anything is.
practical? no.
it will be a massive waste of your time and money. its far from bolt in.
you can get LSD centers for the R200 you already have
Old Aug 6, 2010 | 12:43 AM
What would the best bang for my buck be for an lsd sense I can't find one off an z31.
P.S. For the guys that helped with my question Thanx.
Old Aug 6, 2010 | 11:59 AM
people have stuck the Z32 diff in S30's and Q45. this is probably what you were thinking of:
http://arizonazcar.com/diffmount.html
but like i said, that is for the S30 not the S130. But yes a Z31 lsd diff can go in fairly easily or like skib said, just get an LSD center section replacement that fits into your stock casing.
Old Aug 6, 2010 | 03:19 PM
260zturbo's Avatar
Stupid Hurricanes...
http://www.z31performance.com/forum/...php?f=3&t=6294 BUT finding a CLSD is prob the most easiest way.
