Low end power loss bluez
Old May 10, 2003 | 06:12 PM
lifegrddude's Avatar
Externally Wastegated
At about what rpms is the bog occurring at? Also, how is the bog? Is it a continuous misfire? A little explanation will help clear up things a bit. Below 3000, most Z's are slow due to the low compression they run compared to say a Honda that runs 9:1 and higher depending on trim. My car's 7.4:1 makes it feel extremely slow off boost and below 2600 revs. If I were to accelerate with out boost and prespool, it'd take me about 20 seconds to hit 50 mph! Saves a lot of gas though as I was able to pull 22 mpg with my p.o.s. a/t. Normally only pull about 17-19 mpg.
John
Old May 10, 2003 | 07:14 PM
icice9's Avatar
Super Siver & Black Stud
another possibility is that his clutch might be slipping.....
Old May 23, 2003 | 09:01 AM
The car might just have low compression on all cylinders and not have much torque. And 3300 is the max payload. A 280ZX weighs about 2800 and the 2+2 2980.
The 240Z guys like to say all ZX's weight 3000+ lbs! According to nissan's information (which sounds strange) a 280Z weighs about 40 lbs more than a 280zx. Probably comparing 1978 to 1979 with no power options.
Fozy
Mar 28, 2011 07:42 PM
mikesz
May 29, 2008 11:06 AM
Cw2435
350Z Performance / Technical
14
Feb 22, 2004 10:33 PM
Cw2435
Jan 18, 2004 05:29 AM
280zdriver_16
Jan 9, 2004 10:39 AM
