Lightweight Flywheel?
Old Feb 28, 2005 | 01:19 PM
RodMoyes's Avatar
Doesn't post much...
I am looking for a good light-weight flywheel ('80 n/a) without spending a bloody fortune. Anybody got any ideas?
Rod.
Old Feb 28, 2005 | 02:54 PM
DoTheDrew888's Avatar
Check www.ebaymotors.com I found one on there for $300 the other day. One thing you will have to keep in mind is that the turbo and 2+2 flywheels have a larger friction surface. Almost all the lightened flywheels I have found have the larger friction surface. It will still work on your car, you will just have to buy a clutch for the turbo or 2+2. My personal suggestion would be to go with the larger lightened flywheel and get a Centerforce Dual Friction clutch for the 280ZX 2+2 from MSA. Don't worry it will all fit on your car and will give you that much more "grab" epecially under heavy power loads.
Old Feb 28, 2005 | 08:18 PM
s/cL3.0's Avatar
Bleach is my Hero
For 349 I think you can get 1 from Motorsport, Mine works real good almost 1 year and no probs.
Old Mar 1, 2005 | 06:50 AM
What differences in performance did you notice with the lightened flywheel?
Old Mar 1, 2005 | 09:55 AM
s/cL3.0's Avatar
Bleach is my Hero
I actually installed the flywheel & a centerforce Dual Friction clutch at the same time, the engine definetly revs faster and I did lower my 1/4 mile time by about half a second but I figure that is from it grabbing harder... But over all I like the setup.. I always figure if you have to go that far under the car replace all at once if possible..
Old Apr 14, 2005 | 06:05 PM
Heat Rave R's Avatar
Does that aftermarket clutch make it harder to press the clutch pedal?
Old Apr 14, 2005 | 06:43 PM
Slightly harder but not so bad that its annoying. I kinda like a little more tension it the clutch pedal. I don't think you should worry about it though. I have a Centerforce Dual Friction clutch and I love it.
Old Apr 14, 2005 | 08:12 PM
Skully's Avatar
yup thats what i gotta get when i get my freakin engine in there...my na flywheel and clutch are too small for a turbo setup.
Old Apr 15, 2005 | 01:40 PM
Between the Centerforce II and the Centerforce Dual Friction clutch, which do you guys think has stiffer pedal pressure?
ITSZX
Mar 2, 2015 08:00 AM
slownrusty
Apr 1, 2012 03:12 PM
Jared
FS: 300ZX (90-96)
Feb 8, 2010 06:18 PM
JPerkins
Sep 17, 2007 08:52 AM
nuzxowner
Feb 18, 2005 09:26 AM
