Leaking fuel injector help
Well I just noticed yesterday that one of my fuel injectors is leaking gas. Should I replace them all or just the one? Is there any performance increase if I upgrade the injectors? What kind should I get?
By the way I have a turbo 280zx
Thanks for the help,
Jamie
Jamie
Well you have a couple of options here, is your leak coming from the injector its self or from the supply line? If its only the line and you have no other problems(injector works fine other than leak) then I would just replace the supply lines. If you have an issue with it running rough or rich or your leak is coming from the body of the injector then I would replace all 6. As far as upgrade to larger injector, I really could not say, I am sure there would be more to it than simply slapping in bigger injectors. I have a 83 turbo and had to replace my injectors I got them at NAPA and I believe there were about $62 a piece for new not rebuilt..........
haha...Well i bought a new injector. But as it turns out it was just the seal leaking. I guess it just became brittle and a big piece snaped off. I put the new injector in anyway with new seals. Problem solved.
Daniel Coffman
Apr 14, 2013 08:26 PM
Turbo Biscuit
Nov 18, 2012 02:09 PM
