intercooler ???????
Old Apr 21, 2003 | 05:08 PM
icice9's Avatar
Super Siver & Black Stud
if i were you and you jsut need an intercooler id go with the 87 - 89 toyota supra turbo one... it might not be as flashy as some out there but it does the job.. and its prolly a lot cheaper too... and since its a intercooler from a supra (which is a 6 cylinder too) its perfect for your application...
Old Apr 21, 2003 | 09:22 PM
lifegrddude's Avatar
Externally Wastegated
You can also use Spearco units. I got one with piping for an early Z from a guy that posted on zcar, and I just have to modify some of the pipes. I'm hoping to that this summer if all goes well. Spearcos are good i/c's, they have the bar and plate design and the larger mass so they can act like a heat sink at lower speeds. You can check out their site for info on dimensions and stuff, they don't make a kit for a Z or ZX.
John 82ZXT
Old Apr 22, 2003 | 03:58 PM
FYI, the kit that Motorsport Auto sells is the HKS kit, it's way cheaper at other online sites like www.optauto.com, they have some stuff for a ZX that's a couple bucks cheaper. The HKS kit is like 500 dollars cheaper there... Search around for an HKS intercooler with a search engine, but yeah, I think it'd probably be better to go the route RatedZ went, it's better bang for buck.
John 82ZXT
Old May 1, 2003 | 05:13 PM
Great pics Lockjaw, I have an i/c that's identical to yours I think. Or at least very similar. I haven't taken measurements, but it's a Spearco and has the same shape and outlets too. Those pics are going to be a good reference point for me when I do this i/c install. How much of the frame did you have to cut out? What did you use to cut the frame with? Just trying to get an idea of how long and what to expect of this project. Are you using a 240SX throttle body by chance?
John 82ZXT
Old May 26, 2003 | 11:51 AM
I've heard from others that a 944 i/c is okay to use, but don't quote me on it. I've never seen a 944 i/c up close, but from the pics it looks like it's good to go. How much boost is a relevant question as it all depends on i/c efficiency, pressure drop and all that stuff. I'm thinking 12psi maybe before the fuel system will max out, but maybe lockjaw or someone with more knowledge can give a better estimation.
John 82ZXT
Old Jun 11, 2003 | 01:35 PM
hellzbellz83t's Avatar
I'm running 17lbs. boost with the stock turbo and fuel system without leaning out at all. When I was dialing in the boost, it hit 22lbs. without going lean. I don't trust my stock head gasket to withstand any higher than I'm running now. I have heard from several people the stock internals will handle 28lbs. revving at 7000rpm. I'm afraid with the stock cam and valves I would end up floating a valve or blowing my head gasket! That is going to be my next project--valve/head work to squeeze some more hp out of it.
I just drove it over 1000 miles this past weekend and it did fine at those settings. It's fun to see the Corvette guys reactions when they can't shake you on the freeway! The sportbike guys get a kick out of it too, but they just have to shift again and they're gone!
Hey Lockjaw, what have you done to your fuel system besides the 60mm TB?
-Kel
ThoBackZ
May 26, 2014 04:19 PM
300zxman
Mar 8, 2008 11:55 PM
J.Larr
May 7, 2004 08:29 PM
79bigbore280zx
Aug 20, 2003 11:16 AM
Exessive26
Jul 1, 2003 09:45 AM
