inside lighting
Old Mar 17, 2007 | 06:19 AM
14922zx's Avatar
inside lighting
hello,can anyone tell me if there is a commom link for all the inside lights in my 1982zx, i do not have any at all. Thanks Dennis Satterfield
Old Mar 17, 2007 | 09:48 AM
skittle's Avatar
Taste My Rainbow
get a haynes manual and use the search function. Welcome to the site though.
Old Mar 17, 2007 | 11:09 AM
not much has been discussed on this.
1982-83 cars have the door lights and auto-dim feature. I had some problems with my lights once. The auto dimm module had gone bad.
That item is located behind the ECU. On the driver's side to the left of where you feet would be you'll find the ECU behind a plastic panel.
Remove the ECU and behind that there should be two small modules. One will say some thing like Auto-Dim on it. Replace it with a used one from a wrekcing yard or find someone online that has that item. Again, those are only found in the 1982-83 models.
also, the interrior light fuse is a common link. even if the fuse looks good, replace it and see if that helps.
Old Mar 17, 2007 | 05:41 PM
14922zx's Avatar
Cool lighting
Hello, nice to be here on Z forum.this is my #2 Z and it has 96k on it,i have checked the fuses,all seem to be ok,i will have a look at the other.the stock radio has been upgraded with a cd radio and all of that,is any of that wireing connected to any of that stuff??also the voice only sayes lights are on when the swich is off and lights on---thank you all very much for the info. Dennis
Michael Kelley
Sep 4, 2009 06:21 PM
ZBobbyC
350Z Apperance Exterior, Interior
Apr 6, 2007 11:28 AM
BJ BISIG
Oct 11, 2004 06:10 AM
dexy_die
Aug 6, 2003 09:05 PM
WingsofWar
Mar 14, 2002 05:32 AM
