I am having engine trouble
Old Jun 24, 2005 | 11:21 PM
Jason C.'s Avatar
I am 17 and I am trying to restore a 83 280zx turbo. when i got it the paint and
interior had been striped but the motor ran fairly good. The day after I got it I put
the back end up on jackstands to replace a bad axle shaft, the day after that the
car would not crank.that was a month ago and I still can not get it to run. I know
it is geting way to much gas but I don't know what else to do. I have changed
fuel regulator, the computer, and all 6 plugs but I haven't had time to check
the injectors. any tips
Old Jun 25, 2005 | 03:05 AM
Is it turning over and trying to catch? Please explain in more detail. And maybe I can narrow it down for you. It could also be out of time. That happened to me a couple of weeks ago. My dizzy wasn't tight enough, and it turned on me. Anyway let me know some more detailed info, and I will try to help you.
Old Jun 25, 2005 | 04:02 AM
Captain caveman's Avatar
ooo, I c you got an 83 celica. Have you tried any sideways driving with that? I've heard those have a good weight distribution and are light. Similar to the corolla gts.
Old Jun 25, 2005 | 09:56 AM
Jason C.'s Avatar
it is turning over, it just wont crank. after you let it sit for a while and try to crank it, it will try to start but it dont. when you try to start it you can smell gas. i clamped one of the main fuel lines so i could take the fuel regulator off without gas going everywhere, my friend accidentally turned the key and it started up,ran for 4or5 seconds and died. we took the clamp off and it would not crank agin
i checked to see if it was getting a spark and it is getting a yellowish orange spark is that the way it is suposed to be? anyway when i changed the plugs and it still would not crank I took one out to see if I was getting gas to the plugs, and it was sooked with gas, so i think it is a fuel problem.
could oone of the injectors be stuck open? what else should i check?
Old Jun 25, 2005 | 12:20 PM
Funny thing when I left work Friday morning we had a light rain. And I was fooling around and 3 times while I was turning, I whipped the back end around, it was a rush! But I am sure my co-workers thought I was crazy. But it was fun, and when I slid it, I kept it under control. It was great, I am still deserving keeping my name! That and I was showing off some, sometimes it gets me going!
Old Jun 25, 2005 | 12:27 PM
Try your fuel air-mixture screw, turn it one way, and if that doesn't help. Turn it the other way. It is located, by your throttle body. Also since you have a Turbo, I don't know a lot about them. I am sure somebody on here could give you more help. I just have a non-turbo, but sometime I want to convert to a turbo. Also is one of your injectors leaking gas, or is it just giving too much? Also maybe your fuel regulator is bad, and can't register properly. I really wish I could give you more input, but I am not real familiar with turbos.
Old Jun 25, 2005 | 12:57 PM
assimilated420's Avatar
you should have a bright blue spark if i am no mistaken.. change cap rotor and plugs and see what happens.. sounds like the spark isnt powerful enough so you start flooding the engine and when you clamped the line it leaned it out enough to get it to start but because its clamped it died.. so check your fuel, spark, and air, and compression.. those 4 things you need to run..
Old Jun 25, 2005 | 12:59 PM
jfairladyz's Avatar
No, the spark should be bluish in color. You're getting a really weak spark if its yellowish orange. Those are the lowest colors on the heat index other than red, which means your spark is not very hot at all. I'd lay off the fuel system and focus on the ignition system. Check your coil, cap and wires to start.
Old Jun 25, 2005 | 01:23 PM
Jason C.'s Avatar
The spark is probably the problem, thanks for the help
Flyboy86
Jun 7, 2009 07:02 PM
hobo105
Nov 9, 2007 02:57 PM
Jason C.
Aug 10, 2005 08:09 PM
zkyle
Jul 24, 2002 10:26 PM
zkyle
Feb 13, 2002 11:39 AM
