Help with a Part Name
Old Mar 14, 2005 | 01:41 PM
Red-Eye's Avatar
On my 83 NA, there's a piece that hooks into the base of the thermostat housing with 3 vacuum lines hooked to it. I broke off one of the nipples and want to replace this unit, but have no idea what to ask for. And can I get it from a place like NAPA, or is it a dealer item? Thanks...Robert
Old Mar 15, 2005 | 09:16 AM
EatmyDust's Avatar
Yea man that peac has to do with your water temp I don't remember the name right off hand, but if you order the 20th anaversery magazine frome motor sport it has that, and every other part like that in there in the back you can order it. Motorsport.com.
Old Mar 15, 2005 | 03:44 PM
Heat Rave R's Avatar
Is it a small plastic piece for your vacuum distribution? If so, you can pick one up from Kragen or Pepboys. It's called a vacuum t-adapter; they have all manner of shapes and sizes.
Old Apr 21, 2005 | 07:35 AM
Red-Eye's Avatar
In case anyone cares, that part is called a Thermal Vacuum Valve. Here's what the Nissan FSM says: The valve opens and closes to either permit or obstruct external air passing to the distributer vacuum line. When the valve opens, the vacuum signal line will allow external air to enter, thereby stopping the distributer vacuum from advancing.
BTW, it's $50 for that sucker...Robert
kdxzx
FS: 300ZX (84-89)
13
Feb 1, 2015 11:23 AM
Zsteve
FS: 300ZX (84-89)
19
Jun 13, 2014 09:58 PM
arte
Jan 21, 2014 08:57 PM
ThermalWake
Sep 7, 2005 10:33 PM
