Have a chance to score a 280z cheap... Q's
Old Aug 14, 2003 | 07:03 PM
lifegrddude's Avatar
Externally Wastegated
Hi and welcome to the site! That's an awesome Caddy and I don't think there is anyone else with a 6spd m/t in theirs. That's cool. Well, some pointers for the turbo are to look at the injectors and make sure they don't leak and aren't wet around them, inspect the vacuum hoses on the underside of the intake manifold, check the turbo for play and look closely at the frame rails for rust cause those suckers love to rust. You could also look at the right rear spare tire well to see if there's rust, and also check the rubber boot to the air flow meter since lately there has been a lot of talk about those being cracked. Still though 400 bucks is a great deal on a turbo.
John 82ZXT
Old Aug 15, 2003 | 07:12 PM
duckyz's Avatar
My '83 280ZX n/a had a flooding problem. I replaced all the vac hoses, dropped the gas tank and cleaned it out, put a hi-flow fuel pump on it, and it runs stronger than when I bought it 10 yrs ago.
I don't know if that will solve your problem, but that's how I solved mine.
Old Aug 16, 2003 | 10:38 AM
zhome.com has a lot of info on what to look out for in a Z, you can try hybridz.org and zcar.com both are good sites for info too, but the zcar site is a little dated in its setup. For cheap parts, that all depends, if you search through the web sometimes you'll find some cheap things, but the three main sources have been Motorsports Auto, Victoria British and StrictlyZ. Junkyards are a good place for parts, some owners throw their cars away with some good things left on. Kinda makes me wonder what's wrong with them!
Not much else I can think of to look out for, except maybe inspect the manifold bolts to make sure they aren't loose cause I'm in the midst of changing out my gasket due to loose bolts and it's no fun!
John 82ZXT
Old Aug 18, 2003 | 09:06 AM
BASEBALL248's Avatar
Hey Bill from Hampstead. Ifyou check out that 280zxt and do not want to buy, let me know as I will buy and use it as a parts car.
My 83ZXT had a front end crash and I require a parts car.
Thx,
Steve
rsss32
Nov 2, 2014 06:43 PM
zordietrying
Oct 9, 2010 07:43 PM
s13superstar
Dec 5, 2009 12:16 PM
RodMoyes
Apr 29, 2005 09:08 PM
77greenmachine
Apr 16, 2004 06:21 PM
