gasket!
Old Aug 9, 2004 | 07:37 PM
Skully's Avatar
gasket!
injector was leaking bad and car idled at normal....now i fixed the leak and car idles at 1200-2000
also...
would a slit in the intake gasket cause the car to idle higher then usual
took off intake and made a slit in the gasket, now i put some of that rubber gasket crap on and closed the hole.......i know i know replace any time you take it off but i was in a hurry....
also this is off topic does anybody know where a Chevy 95 lumina/monte carlo 3.1L idle screw is???
Old Aug 10, 2004 | 08:42 AM
Why did you make a slit in the gasket? That doesnt' make sense.
If you have an air leak on the intake, yes that will cause the car to idle high. Try spraying a small amount of starting fluid near where you think the vaccume leak is; while the engine is idling. If the idle goes up, it sucked the mist in and you know where your leak is. Maybe you'll need to replace the gasket.
Old Aug 10, 2004 | 09:03 AM
Skully's Avatar
well i tought id try a preformance modification by slicing my gasket, higher idle = better take off time RIGHT!!!!???......:P
heheh...i took the manifold off and TORE (is that better) the gasket and was too late to go buy one and i wanted the car running.... ill hafta redo it and put a new gasket in.....
Old Aug 10, 2004 | 09:23 AM
EatmyDust's Avatar
Man fill sorry for you wile the gasket is not that expensive, that is a little bit of work and on top of that is the added anticapation of seeing your roring beuty wake up from her nap. hope you get the stuff you need man.
Old Aug 10, 2004 | 10:08 AM
Skully's Avatar
heh ah well
i already had it out driving around with no interior, a spray can paint job and the body kit still in primer with one seat in there and a ghetto a$$ intake system set up JUST so i could drive it before winter kicks. I WAS suppose to finish it this summer but i had little time cuz i worked so much overtime...but now parents bought a house so i have a garage!!!!! i can work on it in winter when im super bored!!!
Old Aug 11, 2004 | 08:44 AM
That is so funny! I've never heard of a vaccume leak being considered a performance modification! hehe... sounds more like you'll run lean and lose power. Never have a vaccume leak after the Air Flow Meter. You know better Skully.
Old Aug 11, 2004 | 10:20 AM
Skully's Avatar
heheheh ahhh...
haha nice reply on the other post
Old Aug 12, 2004 | 01:38 PM
cerealkilla's Avatar
well you know that all the stickers and HUGE spoilers on hondas make them faster.
excel8927
Apr 15, 2011 03:10 PM
Warpix
Jun 11, 2009 09:19 PM
User395
Feb 19, 2009 08:03 PM
AllmyZs
Oct 26, 2004 08:44 PM
Skully
Jun 7, 2003 04:07 PM
