Fuel system problem
ok so I have a 81 280zx N/A and when I turn the key to the Acc. position I can hear the fuel pump runing and it does not stop or at least it sounds like the pump is running. I have not found any leaks anywhere and was wondering if anyone may know something im missing
thanks guys |
Originally Posted by BrownBomberZ
(Post 295634)
thanks guys Basically what is going on is the fuel pressure regulator is meeting the quota and sending the fuel back into the tank, so, nothing is really being used other than electricity. Someone correct me if I'm wrong. |
thats what I was thinking, but was not sure if it sure keep running or if it was just put the fuel back to the tank till fired.
Clean the L connectors on the oil pressure sender and the Alternator. If one or the other is unhooked it makes the fuel pump run any time the system has power.
If that didn't help check the fuel pump relay |
| All times are GMT -7. The time now is 06:13 AM. |
