Fuel system problem
Old May 19, 2011 | 07:51 PM
BrownBomberZ's Avatar
Fuel system problem
ok so I have a 81 280zx N/A and when I turn the key to the Acc. position I can hear the fuel pump runing and it does not stop or at least it sounds like the pump is running. I have not found any leaks anywhere and was wondering if anyone may know something im missing
thanks guys
Old May 20, 2011 | 12:55 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
thanks guys
I think mine did (memory from two years ago when it last ran) on acc.. I know my FC does on acc. because the PO was a POS and wired my pump like a retard. But in my other cars the fuel pump does not run on accessory, why should it, the pump is not an accessory.
Basically what is going on is the fuel pressure regulator is meeting the quota and sending the fuel back into the tank, so, nothing is really being used other than electricity.
Someone correct me if I'm wrong.
Old May 20, 2011 | 01:48 PM
thats what I was thinking, but was not sure if it sure keep running or if it was just put the fuel back to the tank till fired.
Old May 20, 2011 | 05:18 PM
BlueKitsune's Avatar
Intrawebz Wizard
Clean the L connectors on the oil pressure sender and the Alternator. If one or the other is unhooked it makes the fuel pump run any time the system has power.
If that didn't help check the fuel pump relay
hunter_t
May 1, 2014 11:59 AM
Gingie
Jan 26, 2014 06:02 PM
BrownBomberZ
Apr 27, 2012 02:02 PM
skirkland1980
May 1, 2010 02:57 AM
rifleman502
Sep 3, 2004 01:57 PM
