Flattop pistons
Old 07-30-2003, 08:34 AM
You will probably get some noticable torque and horsepower increase. Somewhere in the range of 12 lbs of torque and 10hp at the wheels. The higher compression will also make better use of a performance cam should you go with one in the future. That will again boost your peak horsepower. The cam is a major drawback on the stock engine. But they put down some good torque at really low rpm.
Bleach is offline
Old 07-30-2003, 07:17 PM
duckyz's Avatar
Now....I may be mistaken.....but didn't Datsun go with flat top pistons in '78?
duckyz is offline
Old 07-31-2003, 12:35 PM
1981-83 non-turbo got the first flat tops in the L6. That is the point where they changed the block casting to the F54 block. Better cooling channels and a more rigid design for the 'brand new' turbo engine. They went ahead and used the same F54 block in the non-turbo and used flat tops in the n/a and dished in the turbo. (low compression for the turbo)
Basically 1975-80 engines are all the same. 170 crank hp and about 135 whp. Changing over to flat tops and using a closed chambered head in 1981 got about +10hp at the wheels and about 10 more lbs of torque. Of course with all the electric options going into the 280zx by that year the thing probably weighed 100 lbs more than most of the '79 and '80 models.
Bleach is offline
Old 07-31-2003, 07:02 PM
duckyz's Avatar
I stand corrected.................thanx for the info!!
duckyz is offline
DoTheDrew888
03-09-2005 12:39 PM
DoTheDrew888
03-07-2005 07:09 PM
ZVOITURE
12-29-2003 03:53 PM
awd92gsx
04-09-2002 09:23 PM
Bob240z
05-17-2001 05:42 PM
Quick Reply: Flattop pistons
